check engine light runs rough. idles rough.
Old 10-03-2018, 06:01 PM
tymiller's Avatar
tymiller
tymiller is offline
96 powerstroke 7.3 220,000 miles. has a bully dog programmer hooked up,not through the obd port its hard wired under hood next to the fan motor.a/c inlet shroud. water was in fuel,i dropped the tank and thoroughly cleaned it. disconnected fuel lines and from lack of compressor i gravity drained the fuel lines.had to replace injector harness on passenger side rear harness, (my truck was vandolized and disrespected)it had been cut. i replaced the cam position sensor today, no change. please help
Old 10-03-2018, 08:12 PM
Talyn's Avatar
Talyn
Talyn is offline
So had water in fuel, you cleaned fuel lines and tank(s).
Replaced passenger side rear harness? the one under the valve cover?
CPS wont cause a rough run, it will cause run or no run.
Is it sounding like its missing and shaking really bad, or just sound like its running rough? You still might have a injector harness issue.
Philphan
09-12-2012 09:15 AM
Kizziah
08-05-2008 12:37 AM
erl_berner
07-05-2005 12:07 PM
marcus2576
08-18-2004 05:26 PM
turtle dave
07-30-2004 07:58 PM
Quick Reply: check engine light runs rough. idles rough.
