Hay all! I have recently started some restorations on my 68 F100. One of the first things I wan't to do is get the gauges working, as the truck is my daily and I want' to make sure everything is in order while driving. For the life of me I can't seem to be able to find the Temperature sending unit or oil pressure? Any help on identifying these would be greatly appreciated!
1968 Ford F100, 240 I6
temp sender right side kind of under the manifold towards the firewall.
like ben said oil sender left side easy to locate. if you remove the temp sender it will dump a lot of coolant if you don't drain the radiator some
Thanks! I think someone at some time plugged the original temp sensor hole and mounted one @ the thermostat housing. Nothing that looks like a sending unit in the locations stated but I do see a plug inline around the therm housing. No wires unfortunately. Any of you seen a repair manual for the I6 Ford's?
Go to books4cars.com.
Pick up on these Ford shop manuals.
68 chassis & transmission Ford Truck Shop manual Volume 1 (68_TrkV1Ser)$34.95 ✚ Add to Cart
68 engine ignition system fuel system cooling system exhaust system; Truck Shop Service Repair Manual volume 2 by Ford (68_TrkV2Serv)$34.95 ✚ Add to Cart
68 body & electrical Truck Service manual, Volume 3 by Ford (68_TrkV3Serv)$14.95 ✚ Add to Cart
OR THIS........
68 truck 3-volume shop service repair manual set by Ford Truck for F100 F150 F250 F350 F450 F550 F650 and more.. (68_FSMT)$84.95 ✚ Add to Cart
AND THIS ......68 Wiring Diagram Manual by Ford Truck for F100 F250 F350 (68_MP0385)$16.95 ✚ Add to Cart
Thanks Jeff! I have been looking for good service manuals and these sound like they will come in really handy! ! I have managed to find the temperature sending unit as well as a wire that was dangling. Once I plugged it in, I got temp reading!
