FE engine build
Old Oct 6, 2018 | 04:01 PM
idhiboy's Avatar
idhiboy
FE engine build
Would this work for my F250 truck, as the engine was pulled from a mustang....
"Rebuilt Ford FE 410 engine" The 410 is a Ford 390 block with the 428 1U crankshaft. This block has been bored 60 over so the actual cubic inch is a 422. All machine work is complete. New pistons, rings, bearings, the works. The cam is a Lunauti Voodoo. The heads are the 6090 R and have had the exhaust bosses drilled for the 16 bolt cobra manifolds. They are also fitted with new valves, hardened seats, and the matching Lunnauti heavy duty springs.
My current FE 390 is getting old and tired and this engine I found for sale is just recently rebuilt, just needs gaskets etc and install.... I have edel performer intake and FPA headers
Suggestions?
thanks!
Old Oct 6, 2018 | 09:59 PM
hivoltj's Avatar
hivoltj
I'm no FE expert but .060" over is a lot.
Old Oct 7, 2018 | 08:44 AM
orich's Avatar
orich
At taking a block out to .060 over I'd hope the shop did a sonic test on the cyl.
But back in the day, I had a 1961 HP 390 Bored out to .060 over myself an ran 11.1 pistons that= 4.1/8 and cut heads 060 with no problems.
I never had any over heating issues in a 55 2dr cp. but fan was very close to the radiator no shroud.
Orich .
Old Oct 10, 2018 | 12:51 PM
idhiboy's Avatar
idhiboy
Orich .
Orich
Thanks, for input. I have some concerns too, as don't know the whole history on block/boring/sonic testing etc.... or the shop that did it.... I think it may be safer to just start from scratch with a block that hasn't had work done on it before
thanks!
Old Oct 10, 2018 | 05:49 PM
Alex from GA's Avatar
Alex from GA
If you trust the builder I'd run it. The only thing I'd look at is the cam. There are many versions of Lunati Voodoo cams from mild to not so mild.
Old Oct 10, 2018 | 07:31 PM
orich's Avatar
orich
I'd try to find out who did the boring an see what they can tell you if they did any wall testing etc.
Orich
tai-tanium
Jun 12, 2004 02:38 PM
gtex
Jan 16, 2003 10:04 PM
MufassaMaxx
Jul 4, 2002 06:49 AM
horsetruck
Mar 5, 2002 11:35 AM
