Backup alarm electrical ?
Old Oct 1, 2018 | 07:41 AM
17 Oaks's Avatar
17 Oaks
Getting ready to order my '19 F 350, want the backup alarm but am told the factory install I cannot wire it thru the upfitter switches as there is not way of doing that. My '17 I added the backup alarm since it did not come with it and ran it thru the Upfitter switches.
I use the back up alarm, but do not want it being turned on every time I put it in reverse.
Any of you guys rewired the OEM backup alarm to take it from Reverse to the Upfitter switch? Or should I just get it without and install after I buy it like I did on my 17?
Old Oct 1, 2018 | 08:09 AM
2018f250stx's Avatar
2018f250stx
no reason you cant have a relay brake power at the sounder controled by your upfitter switch
Old Oct 1, 2018 | 02:23 PM
stormrider151's Avatar
stormrider151
I just bought a backup alarm and wired it to switch #2. I put it in the same place that ford does. Works great.
Old Oct 2, 2018 | 08:47 AM
Mud Doc's Avatar
Mud Doc
There is an off function to disable it when you start to back up. Little harder than an upfitter switch but thumb-operated on the steering wheel.
Old Oct 2, 2018 | 08:59 AM
17 Oaks's Avatar
17 Oaks
I have never seen such on any of my truck with it, can you take a pic or describe more.
NOTE the back up alarm aka garbage truck beeper is very LOUD, the back warning that appears on the dash when you put it in R is a sound only heard inside the cab, just to make sure we are talking same same.
pickerdd
Sep 14, 2017 04:27 PM
17 Oaks
Oct 6, 2016 08:17 PM
17 Oaks
6.7L Power Stroke Diesel
Mar 3, 2015 01:41 PM
FSJ-EARL
Jan 2, 2011 01:18 PM
