Disable Backup Alarm
Old Mar 20, 2017 | 08:59 AM
pickerdd's Avatar
pickerdd
Is there a way to disable the back up alarm? I selected it as one of my options on the truck, but I'd like to disable it for a while.
Thanks!
Old Mar 20, 2017 | 10:41 AM
jimzpsd's Avatar
jimzpsd
I don't know where the factory mounts it, but if you find it cut the positive wire going to it and seal it off permanently. And "if" you have the up-fitter switches, run a wire from a switch to the existing alarm, this way you can use it when its needed.
My truck didn't have one but I did install an after-market unit and wired it to an up-fitter switch.
Old Mar 20, 2017 | 10:51 AM
17 Oaks's Avatar
17 Oaks
X2, ran mine thru the upfit #3 so I turn it on and off as needed.
Bonus: Was at a festival Sat and had to get into the area to load up, drove thru the crowds that were walking the street and hanging around after close. Flipped on my #3 and the alarm comes on, catching their attention, sure helped me get thru the crowds easy, so it works going forward or in reverse...
Old Mar 20, 2017 | 12:09 PM
pickerdd's Avatar
pickerdd
Great ideas on linking the alarm to an upfitter switch. Thanks!
Old Sep 14, 2017 | 03:55 PM
CommercialRig's Avatar
CommercialRig
When running upfit wire directly to backup horn is there a need to add an inline fuse along the way?
I definitely like the idea of activating the horn with a flick of a switch rather than attaching to reverse light.....
Old Sep 14, 2017 | 04:13 PM
stufarmer's Avatar
stufarmer
My dealer did it for me. They plunged into the OBD port and turned it off.
Old Sep 14, 2017 | 04:27 PM
jimzpsd's Avatar
jimzpsd
No fuse is needed from you, its already in the circuit along with the proper relay.
17 Oaks
Oct 2, 2018 08:59 AM
17 Oaks
6.7L Power Stroke Diesel
Mar 3, 2015 01:41 PM
marcogyver
Jul 13, 2014 01:59 PM
iggy2
Sep 13, 2011 10:54 PM
