Stuck Dizzy
Old Sep 27, 2018 | 08:16 PM
mountainkowboy's Avatar
mountainkowboy
Stuck Dizzy
Anyone got an idea of how to get it unstuck, won't budge, feels like it's gonna break before it will move. I've tried penetrating oil, WD40, Diesel, ATF/acetone...even letting it sit in the valley for a few days...and nothin...out of ideas.
The reason is to set it back to stock timing..tired of running premium all the time.
Old Sep 27, 2018 | 08:30 PM
daltonjamesadams's Avatar
daltonjamesadams
I had one in an old 351M that was that way, i soaked it for a few days, used an oil filter wrench on it, that way pressure was even.It might work.
Old Sep 27, 2018 | 08:58 PM
ZombieF150's Avatar
ZombieF150
Have you tried tapping it gently as you try to move it?
Old Sep 27, 2018 | 10:58 PM
timbersteel's Avatar
timbersteel
Try taking a 2x4 and lying it length ways over each fender. Then use a ratchet strap and wrap it around the dizzy. Then see it will budge. You may want to remove the rotor and cap prior to trying, if you haven't already done so.
I would also use a towel or something on each side of the fender. I've also seen a bottle jack used as a means to pop it loose from the housing. Patience is the key here.
MikePacey
Feb 18, 2011 05:16 AM
Hmann
Nov 19, 2009 07:32 PM
StanleyZ
6.4L Power Stroke Diesel
Sep 1, 2009 09:06 AM
gingerbreadmaniac
Jun 13, 2005 01:36 PM
Ugly
Apr 26, 2002 04:10 AM
