2 transmission questions
Old Sep 27, 2018 | 06:52 PM
bigb56's Avatar
bigb56
1. If I pull the shifter into "2" while going too fast, will the transmission wait till the speed is lower before going into 2nd or will it just go into second, or first for that matter, at any speed (4R100)?
2. My overdrive button has started to not work intermittently, seems when it won't work if I push the shift lever forward while pressing the OD button then it will work. It is the same whether shifting into or out of OD.
Thanks
Old Sep 27, 2018 | 07:01 PM
FordTruckNoob's Avatar
FordTruckNoob
To answer question 2, it sounds like you have a chafed wire where the shift lever pivots on the steering column. Read this thread:
https://www.ford-trucks.com/forums/s...=815615&page=2
Old Sep 27, 2018 | 07:06 PM
bigb56's Avatar
bigb56
That's the first thing I though but last month I had the plastic cover off the column to wire in my new mirror turn signals and I inspected the shifter harness and didn't see anything, could've missed it I guess.
Old Sep 27, 2018 | 08:28 PM
timmyboy76's Avatar
timmyboy76
Now that, wouldve been 1 cool thread/tutorial.
Old Sep 28, 2018 | 05:16 AM
FordTruckNoob
Hmmmm, have you checked the switch itself? You can pull it out the end of the shift lever to test continuity when pressed.
Old Sep 28, 2018 | 08:25 AM
bigb56's Avatar
bigb56
No I didn't know that button just pulls out. I was looking online for the complete shift lever with harness but it looks like it is all sold separately....thanks
Old Sep 28, 2018 | 03:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The trans will shift to 2 at any speed. It will not shift to 1 until it's slowed to a safe speed.
Old Sep 28, 2018 | 10:42 PM
bigb56's Avatar
bigb56
Thanks Mark. I guess the best way to know when it is safe to shift down into 2nd is see how high the RPMs reach when accelerating in 2nd before redlining and use that speed for your maximum safe downshift speed when descending.
jerwiltho
Nov 27, 2013 11:44 AM
eigood56
Sep 8, 2010 07:20 PM
fastcam
Dec 2, 2009 08:40 PM
Rtpjunior
Feb 15, 2003 06:25 PM
