Sponsored by: Real Truck
5r110 issues
Old Sep 27, 2018 | 11:30 AM
bankspro6811's Avatar
bankspro6811
5r110 issues
I'm getting a code for solenoid D which is the "direct clutch solenoid" and having trouble shifting from 3rd to 4th.
would that solenoid also cause my reverse gear to be jumpy or could I also have something wrong with my reverse solenoid?
Old Sep 27, 2018 | 11:43 AM
MisterCMK's Avatar
MisterCMK
What code is being set?
MisterCMK's Avatar
MisterCMK
The direct clutch is also used in reverse so it can cause reverse issues.
Old Sep 27, 2018 | 11:48 AM
bankspro6811
P0766 - shift solenoid D performance stuck off
P2703 - Trans function element D apply time range / performance
Old Sep 29, 2018 | 10:06 AM
MisterCMK's Avatar
MisterCMK
You are probably looking at a burned up direct clutch. Been there, done that.
Old Oct 10, 2018 | 12:44 PM
bankspro6811
I assume that's a total rebuild?
Also...I just replaced the direct clutch solenoid and am still having the same issue.
Old Oct 10, 2018 | 10:29 PM
MisterCMK's Avatar
MisterCMK
I did the same thing when I smoked a direct clutch.
You're looking at a full overhaul unfortunately. Sorry, it sucks, I know.
mtsnieg
Nov 20, 2023 09:56 AM
AKHunter93
30
Nov 6, 2019 03:16 PM
Crcase
Oct 28, 2014 03:39 PM
Wild-Bill
Dec 12, 2013 05:56 AM
Country705
Feb 11, 2007 08:45 AM
