6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Alternator?
Old 09-25-2018, 10:34 PM
ceschrader's Avatar
ceschrader
ceschrader is offline
Alternator?
Just bought a 2010 F250 6.4. While driving the RPMs and Speedometer will drop to zero and several warning lights will come on (brakes and seat belt). That lasts for a few seconds then everything returns to normal. I'm thinking alternator, what do you guys think? Thanks in advance.
Old 09-26-2018, 03:12 AM
seville009's Avatar
seville009
seville009 is offline
i’d think the battery light would come on, but you never know. Just test the battery and alternator.
Old 09-26-2018, 04:13 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
my vote is on either a ground or other loose electrical connector.
alternator would light up you battery red indicator.
Old 09-30-2018, 05:31 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
My wife drives my future truck. Just went down to the local boozery to watch the Lions loose, and took this rig because I have my 99 brakes gutted.
At start up, both rpm and tach needles did a little dance until the glow plugs timed out. Then everything was ops normal. My running voltage is 14.3-4 so my alt is good. Truck sat in the garage for four days prior and my batteries are 5 years old.
I would consider (with these electronically finicky trucks) Getting a fresh set of good batteries if your due.
If they're older, save yourself the headache. I'm going to.
Denny
Old 09-30-2018, 06:23 PM
speakerfritz
I just went thru this
replaced alternator and two batteries
the battery that failed the load test showed 12.4 volts static with no connections.
but....it draws almost 40 amps to charge it.....forever.
frdf250
02-08-2017 06:19 PM
Slankky
08-19-2012 02:02 PM
Tim J
15
11-12-2008 02:39 PM
BillyBob69
1999 to 2016 Super Duty
08-10-2007 07:35 PM
bobward737
1997-2006 Expedition & Navigator
03-26-2003 08:43 AM
Quick Reply: Alternator?
