Sponsored by: Real Truck
Alternator or battery
Old Aug 9, 2007 | 01:07 PM
BillyBob69's Avatar
BillyBob69
Normally this is a DUH fix and I wouldn't ask...but about a month ago, I noticed that my bettery light came on for a few seconds, went out, back on flickering a little then out again. Well my charge gauge shows good, although I don't put alot in the factory gauges...and it didn't happenagain until about 4 dyas later. Now here is the kicker...it happened in tha same place on the way to work. Well after the second round. Nothing for about 2 weeks...then it did it again..on the same stretch of road.
Alternator...battery....aliens?
Lights don't flicker, nothing seems dimmed everything else works fine. I had the alternator checked out and that showed fine...the batteries show a good charge and holding....Thoughts?
Old Aug 9, 2007 | 02:15 PM
redford's Avatar
redford
FTE Leadership Emeritus
I would bet that you have fried a few of the recitfying diodes in your alternator. The others are trying to do double work to make up for it, but cant pass as much current as your truck is demanding at that given instant. This is why you are getting a voltage drop and a battery light.
Your alternator is probably doing a slow death. I would pull it and toake it to your local Auto Zone for a freebie load test.
Old Aug 9, 2007 | 02:18 PM
BillyBob69's Avatar
BillyBob69
Thats what I did...they called it good. Although...now that I think about it...it had been raining the night before when I saw the light....but it has been raining lately for about the past 4 days and it hasn't come on again.
Old Aug 9, 2007 | 02:20 PM
redford's Avatar
redford
Could just be a slipping serpentine belt then.
Old Aug 9, 2007 | 03:03 PM
cgl's Avatar
cgl
Sounds like what I went through. Look at my post..
https://www.ford-trucks.com/forums/5...67x-codes.html
I haven't had one more problem after replacing my alternator.
Old Aug 9, 2007 | 03:10 PM
BillyBob69's Avatar
BillyBob69
Thanks guys! I'll check those out!.
Old Aug 9, 2007 | 05:36 PM
SFeintuch's Avatar
SFeintuch
If you have around 150K on it it could be the brushes are getting short and not pressing on the comutator as hard as a full brush and that would make the light go on and off. Bad Diodes would most probably make light stay on steady. I see an alternator in your future.
Old Aug 9, 2007 | 08:22 PM
rocknmud's Avatar
rocknmud
I am having the same issue and have 42,000 miles. It started this week. Well I hope it is only 1 of 2 alternators!
Old Aug 10, 2007 | 10:05 AM
cgl's Avatar
cgl
With the dual alternator setup, I believe the PCM controls the alternators and should give you a code should one of them fail.
Old Aug 10, 2007 | 10:47 AM
redford's Avatar
redford
Originally Posted by SFeintuch
.... Bad Diodes would most probably make light stay on steady. I see an alternator in your future.
No, because if you lose one or even a few of the diodes in the alternator the rest will still work and supply current to charge the battery, but the total output of the alternator will be limited. An alternator is a 3 phase device with 6 diodes. Under light demands everything will be normal (the remaining diodes on the remaining phases will produce some DC output) but you will get the light of the current draw exceeds the alternator's limited output.
You will also probably notice a static or hum on your truck radio, especially on the AM band, that will change with engine speed.
Old Aug 10, 2007 | 02:13 PM
BillyBob69's Avatar
BillyBob69
168K miles on my truck...prolly the alternator.
Old Aug 10, 2007 | 07:35 PM
vettdvr's Avatar
vettdvr
Yes I agree, brush tension would be down is they were short and high loads might cause it to drop out,, so would heat on 2 working diodes.
OR,,, you had a close enounter with ET.
Shutech
Apr 21, 2015 09:31 PM
handyandy123
Jun 6, 2014 08:17 PM
12valveEx
Aug 16, 2013 08:24 PM
