Battery light on after new alternator and batteries
Not sure why but after I put two new batteries and a new alternator in my truck the battery light came on. I put the new batteries in since they were dead one morning when I went out to start it. I noticed the batteries were only a few months old so I thought maybe the alternator failed? Anyway decided to replace both which lead to the battery light coming on for no reason.
Took the truck to autozone to get the alt tested, checked out fine on the truck and on the bench tester. I decided to put a new belt on it anyway thinking it might be stretched out? Lights still on.
Not sure if its a coincidence but when I unplug the 2 wire pigtail connector that goes to the alt when the trucks running the light turns off. Plug it back in and the light turns back on.
Does anyone have any ideas?
Since your batteries are new, expect to see 12.6-12.8 volts at terminals static.
Check your voltage on the large terminal on the back of the alternator. It should show between 13.6-14.4 volts, but probably at the lower end with fresh batteries.
Also, make sure the two wire plug on the back is secured, re-plugging in and out to ensure.
When running, you can carefully put a long screwdriver on the alternator pulley and feel a magnetic field if operating. Wouldn't be the first time an alternator, particularly rebuilt, failed.
A vom is your best friend right now.
The first time i replaced my alternator with an Autozone 140 amp i immediately had the alternator light on. In my case the terminals did not fit the studs on the alternator exactly like the factory terminals had. The terminals were not nested all the way down making proper connection. Check the simple things.
But it is fixed, so no matter...
I didn't think it was just the connector. Maybe on a first install, but he had it tested on the vehicle then took it off and had it bench tested. He also mentioned the changes when the connector was off to when it was on. That's a whole lot of movements to have it consistently not clicked in. Plus we've had store rebuilds fail out of the box so my confidence was with the installer.
I finally just changed my connector to make the wires longer as with the height of the L-N they are in tension. And I've flipped alternator sooooo many times if there was a fatigue issue within the connector I should have been the poster child.
mchristian
07-08-2015 05:43 PM
