ID Tag Clarafication Please
Old Sep 22, 2018 | 08:52 PM
1957 F100 New Guy's Avatar
1957 F100 New Guy
Greetings All,
My ID plate:
F10K7L13286
118 T 30 H A 01
05000 145 4100
History:
I bought it in March 2017, from the Denver Center for the Perfoming Arts - Theater Company, for $300.00 dollars. I work there as a stagehand. They bought it as a prop two or three years earlier for a show called Sweet and Lucky and never tried to get it running. It was not running when I got it, so I thought I couldn’t make it not run any more. It was the perfect first project. It now starts and idles. I am in the process of putting power disc brakes on it now. Next is the clutch hydraulics.
Thank you,
Matt Wagner
Old Sep 23, 2018 | 03:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Rating Plate decoded
Originally Posted by 1957 F100 New Guy
My Rating Plate:
F10K7L13286 / WB: 118 / COLOR: T / DATE: 30H / TRANS: A / AXLE: 01 / MAX GVW LBS: 05000 / CERT. NET HP: 145 / RPM: 4100
F10 = F100.
K = 272 2V
7 = 1957.
L = Michigan Truck Assembly Plant.
13286 = 1957 Numerical Sequence of Assembly, the trucks specific serial number.
118" Wheelbase.
T = Exterior COLOR code, not listed in truck parts catalog for 1957/60.
30H = Assembled August (H) 30, 1956.
A = Ford 3 Speed Manual Transmission.
01 = Ford 9" Rear Axle / 3.70-1 / 3,300 lbs. Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
145 net HP @ 4,100 RPM
Some 1957's used a unique Rating Plate, did not have a MODEL code stamped between the COLOR & DATE codes.
Old Sep 23, 2018 | 03:50 PM
matthewq4b's Avatar
matthewq4b
F10 = F100.
K = 272 2V
7 = 1957.
118" Wheelbase.
Paint Code T is Woodsmoke Gray M0756 AKA. M20J756
Not listed in the parts manual but listed in the Ford Trim manual and after market catalogues.
Old Sep 24, 2018 | 07:27 AM
1957 F100 New Guy
Thank you Gentlemen.
Hodetoad
Dec 11, 2018 01:56 PM
Highboy4x4
Dec 3, 2018 09:48 AM
Amphihauler
Sep 1, 2018 10:09 AM
1965GTFB
Jun 23, 2018 04:21 PM
Dmac2222
Dec 14, 2017 07:25 PM
