Data plate/transmission
Old Sep 15, 2018 | 09:14 PM
Budro574's Avatar
Budro574
i couldn’t find this information anywhere online. There’s not a single site that shows the transmission code breakdown.....
trans code C. Color code S.
Anyway to to tell if it’s the original transmission that came with the truck? Same with the engine. Is there a vin stamped on the trans or engine?
i have a leak coming from the gear sector lever. Is that a pain? Looks like I have to drop some stuff from the bottom of the trans to get to it.
The dipstick isnt original. Others have said 22 5/8 but that’s where my trans pan bolts are, doesn’t seem long enough to give a low or full rating. Full is 2 inches plus from the bottom of the dip stick.
Old Sep 15, 2018 | 09:19 PM
Budro574's Avatar
Budro574
Trans has pbm 7006 f stamped on the side
Old Sep 15, 2018 | 10:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Budro574
trans code C
No, numbers matching is a "GM thing."
C = Ford-O-Matic 3 Speed.
What year is the truck, what engine? The pic of the Rating Plate you posted is too blurry to read.
PBM-7006-F is the casting number off the converter housing, it is not the trans ID number.
See pic at upper left for location of the FM (Ford-O-Matic) TRANS ID number.
Old Sep 16, 2018 | 10:49 AM
Budro574's Avatar
Budro574
Thanks for clearing the type of trans for me, so now I can cut the dipstick to size. Any idea on color code S?
Old Sep 16, 2018 | 01:09 PM
NumberDummy
No reference for S for 1957/60. 1956 S was a special non standard color.
Old Sep 17, 2018 | 03:18 PM
Budro574's Avatar
Budro574
That trans dipstick tube nut is frozen, any ideas on removal or replacement? Any measurements on the nut? I would like to repair versus replace. I can’t find anything locally, so I’ll need to order online. All of this internet’s and it’s extremely difficult to gather this kind of information.
I am contemplating purchasing the 1959 ford truck shop manual, y block manual, fordomatic manual, and 1959 ford truck wiring manual. Any experience with any of these?
Old Sep 18, 2018 | 03:53 PM
matthewq4b's Avatar
matthewq4b
Get the shop manuals they are invaluable sources of information.
Is the nut frozen because it is squished or just frozen ?
If it s just stuck put the heat to it and slowly work it back and forth. .
Old Sep 18, 2018 | 08:34 PM
Budro574's Avatar
Budro574
Thanks guys! I purchased the 59 Ford Truck shop manual CD. I bought an o ring kit, because the dipstick seal was trashed and auto zone wanted $3.25 for it. I got a kit of 300 for $4.89 on Amazon. I'll give the heat and shaping a try. Any idea on finding another hex nut/dipstick tube just in case?
Old Sep 20, 2018 | 10:59 AM
NumberDummy
87034-S94 .. A/T Dipstick Tube O-Ring - 1/2" I.D. / Available from Ford - MSRP: $1.00.
1950's/90's Ford-O-Matic; FX/FMX/MX Cruise-O-Matic; C3, C4, C5 & C6; AOD; A4LD; E4OD and etc etc etc.
B9TZ-7A228-C .. A/T Dipstick Tube / Obsolete
1957/58 F250/350; 1957/60 F100.
No Ford dealer or obsolete parts vendor has any.
Old Sep 20, 2018 | 11:11 AM
Budro574's Avatar
Budro574
Thanks for the measurement. I thought it was a 9/16, I think i found that info on the TBIRD forum. So thank you for correcting me!
Old Sep 21, 2018 | 12:19 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I paid 50 cents each for 16 of them. Enough to last a lifetime....lol.
87034-S94 (T1A) - Seal - "O" ring - 1/2" I.D. - rubber - 1 each
Chad
Old Sep 26, 2018 | 06:02 AM
Budro574's Avatar
Budro574
Heated the nut and was able to get it to break free. It still had a warp in it, so I did my best to work it back to shape. I forgot to adjust the bands, so probably going to get that done today. That ball bearing was a beast.
Nathan511
Jan 3, 2017 10:16 AM
emgee
Sep 16, 2015 05:19 PM
BIGskinny
20
May 25, 2011 10:23 PM
Ohio Ford Farm
Jun 18, 2009 03:53 PM
stroked88ranger
16
May 18, 2009 11:33 AM
