T18 Exploded View Please
Old Jun 23, 2018 | 12:47 PM
1965GTFB's Avatar
1965GTFB
Looking for all the Ford shop manual info on a T18.
I'm sure ND will have one.
My 65 Ford shop manual(multi book set) does not show the Warner T18 4 speed. It does show the T98, I'm assuming those are not the same thing. What year manual would cover the T18?
Old Jun 23, 2018 | 01:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No T-98's after 1964.
Two T-18 pics, lower pic shows exploded view of shift lever and misc. parts.
Old Jun 23, 2018 | 01:44 PM
Crop Duster's Avatar
Crop Duster
shop manual
My 1973 truck chassis manual covers the T18 an T19 and just about every other transmission ford put in anything up to a Spicer 16 speed compound. But I would think any year in the 70's would cover it.
Old Jun 23, 2018 | 02:01 PM
1965GTFB's Avatar
1965GTFB
But I'm assuming you could still get a T18 based on the info when you decoded the truck for me(see below). Was the T18 not in the manual because it was normally available unless you special ordered it?
Quote:
Originally Posted by 1965GTFB Can one of you decode the numbers for my 65 F100? Some of the numbers I have figured out but still need help with some.
Also is there a decoding book out there like the one I have for Mustangs?
TIA
F10BR627422
W.B.: 129
Color: It is blank
Model: F100
Body: D81
Trans: F
Axle: 08
Max GVW: 5000
HP: 150
RPM: 3600
DSO: 720815
Welcome to FTE
F10 = F100 2WD
B = 300 1V 1-6
R = San Jose CA Assembly Plant.
627422 = 1965, assembled December 1964.
129" Wheelbase.
No COLOR code.
F100 2WD / 5,000 lbs. GVWR
D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic // 81 = 81B Custom Cab.
F = Borg Warner T-18 4 Speed Manual Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3600 RPM.
720815:
72 = San Jose (NorCal) Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
0815 = Domestic Special Order number. Your truck was special ordered by the original purchaser, not "bought off the lot."
COLOR code blank: One reason your truck was special ordered, it was painted a non standard color.
When a vehicle (car or truck) is painted a color per the customers request that is not an RPO, there is no COLOR code. RPO: Regular Production Order.
I have found that most of those so-called decode books have errors and omissions.
For example, what does your Mustang decode book say about no COLOR code, DSO, and RPO?
btw: The above info was decoded from the 1964/72 Ford Truck Parts Catalog.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
Old Jun 23, 2018 | 02:08 PM
NumberDummy
TRANS code F = Warner T-98 (1957/64).
TRANS code F = Warner T-18: 1965/79 F100/250 2WD
TRANS code N (1965) & TRANS code A (1966/79) = New Process 435: 1965/72 F350; 1965/79 F100/250 2WD/4WD
TRANS code P = Warner T-19: 1973/79 F350.
Standard equipment in F100/250 2WD was the Ford type 3.03 3 speed manual. 3 M/T with Overdrive (1965/71 F100), both the 4 speeds were optional.
Old Jun 23, 2018 | 04:13 PM
1965GTFB's Avatar
1965GTFB
standard equipment in F100/250 2WD was the Ford type 3.03 3 speed manual. 3 M/T with Overdrive (1965/71 F100), both the 4 speeds were optional.
Ahh, so if the 1st owner had left it with the standard OD tranny I might not be doing this Gear Vendor OD install that I am starting on. But this will be better having 8 gears(really 6 as I basically never use the non-synchro 1st) for hills, especially when towing. Could have used an in-between gear a few time on our recent 2,500 mile Southwest trip. Mocked it all up and got the measurements for the new driveshaft done this morning. Off to the driveline shop Monday and while he is building the shaft I'll be resealing the T18, checking and maybe replacing the clutch(I assume it's the original w/ 96K on it), and pulling the flywheel to help with pulling the oil pan to reseal it. It will be nice to stop all the bleeding that's been going on from the old original gaskets.
Old Jun 23, 2018 | 04:21 PM
NumberDummy
Ahh, so if the 1st owner had left it with the standard OD tranny I might not be doing this Gear Vendor OD install...
What standard Overdrive? 3 M/T with Overdrive was optional, TRANS code B.
Ford type 3.03 3 speed all syncromesh M/T was standard equipment. TRANS code A (1965), TRANS code C (1966/79).
The original owner bought the truck with the optional Warner T-18 4 speed.
What most people don't realize is that the bare bones F100/250 standard cab 2WD was a cab & chassis with 240 I-6 & type 3.03 3 M/T as standard equipment. EVERYTHING else was optional.
Highboy4x4
Dec 3, 2018 09:48 AM
1957 F100 New Guy
Sep 24, 2018 07:27 AM
19hoosierdaddies87
Large Truck
Apr 4, 2018 07:02 PM
shanekbms
Nov 4, 2010 06:12 AM
jazzmaffy
Apr 9, 2010 10:50 AM
