Sponsored by: Real Truck
Tow in reverse
Old Sep 22, 2018 | 09:56 AM
Venturous's Avatar
Venturous
Tow in reverse
Hello,
I recently picked up a 2015 F250 Super Duty SWR with 6.2L to haul a new toy hauler travel trailer. Trailer GVWR is 10,000 and I will likely load it to maybe 8500LBs.
This truck pulls is great, even up my steep driveway here in east TN.
My question is.... it would be much easier for where I plan to park if I backed the trailer in. But I am reluctant to try that because I do not know if the reverse gears have enough strength to handle towing up a steep 80 foot driveway or if it has enough torque in reverse. Towing forward the truck qas certainly working but did fine.
Is reverse as strong enough for trying backing up my drive?
Thanks
Gary
Old Sep 22, 2018 | 11:16 AM
Colorado350's Avatar
Colorado350
Gary, Welcome to FTE.
Any my time I need to move something heavy in reverse I put the vehicle in 4L. This will allow for more torque at lower rpm’s and help take the stress off the pinion.
Old Sep 22, 2018 | 11:40 AM
alloro's Avatar
alloro
The switch to 4L is in the t-case which is before the pinions, so the stress on the pinions, ring gears, driveshafts, and axles doesn't change.
Old Sep 22, 2018 | 11:58 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Truck will be fine in forward/reverse/ high or low range. This is a super duty designed for this type of work, it's not a nissan datsun
Old Sep 22, 2018 | 03:22 PM
speedfreak78's Avatar
speedfreak78
Get a front receiver hitch and you could drive it up and have better control.
https://www.ford-trucks.com/how-tos/...r-hitch-361127
Old Sep 24, 2018 | 09:14 PM
jkhuntin's Avatar
jkhuntin
THIS^^^^^, unless it's a 5'er and then it would be kind of difficult. Had a front hitch on my old '75 for moving boats and trailers around, works great.
jk
Old Sep 25, 2018 | 09:47 AM
Ron94150's Avatar
Ron94150
You probably have 3.73 gears. I've switched to 4.88's and have the 3.73's sitting in a box. These gears are massive. I can assure you that the 405 ft lbs of torque you have is not going to hurt it, especially since they hold up to diesels pushing over 1000. While putting a hitch on the front would give you the best control, if your backing up an 80 foot driveway, I'm guessing those tow mirrors would come in handy so you can see what you are actually doing. Reverse is a 3.12 ratio, so it's plenty low enough.
Old Sep 25, 2018 | 02:13 PM
redford's Avatar
redford
FTE Leadership Emeritus
The 1st generation Super Duty trucks with the 4R100 transmissions had a weakness for towing heavy in reverse up a hill. That would often cause a transmission overheat.
Your vehicle does not have this issue. You may want to put the truck in 4L for better low speed torque, but it isn't mandatory.
Old May 21, 2024 | 08:35 PM
SuperdutyChris's Avatar
SuperdutyChris
Can I just unplug the harness to the vacuum hub solenoid for the few times a year I need the 2Lo? I’m not in love with the idea of cutting into the harness on my new truck while still under warranty.
Old May 22, 2024 | 08:51 AM
Diamnd1's Avatar
Diamnd1
You can remove the vacuum tubing from the solenoid as well. I completely removed my vacuum tubing as it was annoying when I need 4 lo for maneuvering something and the front wheels engage. I prefer it that way, plus the hubs get some lubrication when I do have to turn them manually instead of being in Auto.
Old May 22, 2024 | 09:00 AM
SuperdutyChris
Thanks @Diamnd1 We also live in the great white North where 4x4 can be needed daily in the winter, so I think I'll just unplug the solenoid when needed.
Old May 22, 2024 | 09:41 AM
Eman85's Avatar
Eman85
The gears in the automatic transmission are the same whether you are going forward or reverse, the difference is which clutches are engaged.
arby123
Sep 24, 2017 11:06 AM
ontariofarmer
Dec 19, 2014 11:54 PM
deathstar7.3
Jun 2, 2011 04:16 PM
darkmage55
Offroad & 4x4
56
Feb 19, 2010 12:32 AM
fisherj
Oct 2, 2007 05:09 PM
