Ft carb
Old 09-20-2018, 12:38 PM
jwitty's Avatar
jwitty
jwitty is offline
Ft carb
Going to look at a Holley/motorcraft? carb tomorrow For my 352 fe. Only problem is that that carb has something on the side where the throttle cable would hook up. What is that for? Can it be removed? I can get a pic of the carb if you don’t know what I’m talking about. Going to look at it tomorrow so fast help would be awesome thanks
Old 09-20-2018, 02:17 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,626 Likes on 1,326 Posts
A FT carb would have a governor. FT engine had carb and ignition governors to prevent engine and vehicle overspeed. I would not buy one for a 352. Is this a 2bbl or 4bbl?
Old 09-20-2018, 02:19 PM
jwitty's Avatar
jwitty
jwitty is offline
It’s a 4bbl. Can it be removed? He only wants 25 bucks for it. If not I found a 4160 that should work good on the 352 just for 50
Old 09-20-2018, 02:36 PM
85e150's Avatar
85e150
I'm not sure about removing the governor.
4160 could be perfect. I don't know enough about those and all the variations to be sure. Usually for standard 352 600 CFM with vacuum secondaries and, if you can do it, an electric choke is a good setup. $50 is a good price if it's sound. Look it over, check the shafts for any visible slop, cracks, etc. Check linkage for any butchery etc.
Old 09-20-2018, 02:44 PM
jwitty's Avatar
jwitty
jwitty is offline
He went down to 30 so as long as it’s not cracked or anything I’m gonna jump. It does have electric choke. Now I have another question. I got the edelbrock intake on it and want to get rid of heat crossover because carb has been getting too hot. I won’t be running it in the winter so I’m not worried about that. I just ordered felpro gaskets that have that heat crossover pipe blocked. Will that be enough or does it need metal plates. Thanks for your help
Old 09-20-2018, 02:59 PM
85e150's Avatar
85e150
I think some gaskets do the trick. Long discussion here:
https://www.ford-trucks.com/forums/1...r-problem.html
Old 09-20-2018, 03:03 PM
jwitty's Avatar
jwitty
jwitty is offline
alright sweet that answers everything. Thanks!
Old 09-21-2018, 07:59 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
The governor linkage on the FT carb comes off but there's nothing the connect a standard throttle linkage to, you have to change out the throttle shaft with one from a standard carb.
Not worth the trouble, there's other differences to but the throttle shaft kills it.
I used to cut out two small pieces of sheet metal to fit in the hole on a standard intake gasket for blocking the cross over.
Old 09-26-2018, 04:30 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by jwitty
Going to look at a 4V Holley carb tomorrow For my 352 fe. Only problem is that that carb has something on the side where the throttle cable would hook up. What is that for? Can it be removed? I can get a pic of the carb if you don’t know what I’m talking about. Going to look at it tomorrow so fast help would be awesome thanks
1965/67 F100/350 352 used the Auto-Lite 2100 series 2V
Pic: 1964/72 Holley 4V installed on 391 4V FT engines.
Bodyshopboy
20
08-23-2013 09:46 AM
Greenmachine_76
04-25-2010 12:12 PM
wideasleep1
05-29-2005 07:32 PM
Chtulu473
08-21-2003 09:53 AM
Titus Smith
09-17-1999 04:14 PM
Quick Reply: Ft carb
