Carburetor Idenification
Old Sep 17, 1999 | 02:34 PM
Titus Smith
Guest
Posts: n/a
I was wondering if anyone can help me identify
the carb I have on my 66 F250. The engine I
have is a FE352. In the shop manual this engine
came with a 2 barrel carb, the Ford 2V. In my
Chilton manuel it is a Autolite 2100A. The carb
that is on the truck is a 4 barrel. The carb I
have looks to be the same in the area of the
primary fuel bowl, accelerator pump, etc. The
4 barrel carb has an auto choke housing which
has been disabled and the manual pull choke is
attached to the choke plate linkage. The only
numbers I can find on the 4 barrel carb are
"F 1.12" inside a circular stamp on the side
and a "C0AE K" near the base.
I would like to buy a rebuild kit for this but
don't know the carb number.
Old Sep 17, 1999 | 02:59 PM
jowilker's Avatar
jowilker
Old Sep 17, 1999 | 04:14 PM
390fe's Avatar
390fe
If the front of both carbs look alike, then you have an Autolite 4100. I have one also, and the carb number is "C6AF-L". Below that is "B 6EA".
I think these carbs came in two cfm ratings, but I'm not sure. My throttle bores measure 1.6 inches. If your bores are the same, my carb number will probably be enough to get a kit for your carb. By the way, my carb came from a '66 Galaxie with a 352 and a C6.
