460 4x4 engine swap to I6
Old 09-18-2018, 06:19 PM
blairsie's Avatar
blairsie
blairsie is offline
i have a 93 f150 with just over 345k. She's still a solid truck and I want to keep her but I've just moved to the country in mid-Missouri and I need 4x4. I'm tired of getting stuck. There is a 95 f350 4x4 crew cab with a blown 460 for sale nearby for 700$. My question is, will the 300 have enough guts to move the larger truck to highway speeds in a reasonable manner. Will the 350's towing capacity be greatly diminished. Will the 300 bolt straight onto the auto in place? I know ford offered this engine in that body, but I can't imagine that there were too many takers. Would it be difficult to find the right computer for that combo?
Im hoping to be able to tow a 30+ ft fifth wheel trailer with a 40 horse Kubota and random implements on it.
thanks for any feedback
Old 09-18-2018, 07:02 PM
Alderonn's Avatar
Alderonn
Alderonn is offline
Trailering
The bell housing from the small block pattern engine and the big block pattern Trans will not work.
Old 09-18-2018, 08:02 PM
Oneyed Goat's Avatar
Oneyed Goat
Oneyed Goat is offline
Originally Posted by blairsie
95 f350 4x4 crew cab...I know ford offered this engine in that body, but I can't imagine that there were too many takers. Would it be difficult to find the right computer for that combo?
Are you sure? I haven't come across any information that a straight 6 was offered in a 1995 F350 4X4 Crew Cab. I believe the 5.8L was the smallest available and it's (IMO) just enough for light towing duties. If I was going to tow horses and 30 foot fifth wheels, Diesel or 460 minimum.
Old 09-18-2018, 10:31 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is offline
Even empty, that 300 six is going to struggle making highway speeds.
Old 09-18-2018, 11:12 PM
Conanski's Avatar
Conanski
Conanski is online now
Were you around back in the '70s when a truck towing a trailer was the slowest thing on the road, that is where you are headed putting a 150hp motor in a 7000lb truck.
Old 09-19-2018, 03:38 AM
frank5079's Avatar
frank5079
frank5079 is offline
I swapped my 300 for a 351 and I can tell you that the 300 was adequate.....but to swap it into a crew cab 4X4 and expect it to pull an empty fifth wheel trailer would be torture enough. If it were me, I would go with a diesel swap....
Old 09-19-2018, 07:35 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
To be blunt, and waste no time; this is a terrible idea.
Rebuild the 460 if it needs a rebuild.
Old 09-19-2018, 07:47 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
or you could do axle swap on the f150. D60/10.25 8 lug f150 would do pretty good.
You'd still need a trans to bolt to the 300 though...
fords4wheeling
1999 to 2016 Super Duty
08-15-2016 11:39 PM
bullnose1985
16
11-07-2013 01:07 PM
300FOREVER
03-30-2010 11:37 PM
goatchops
08-05-2005 10:00 PM
TrevorH
01-20-2005 04:50 PM
Quick Reply: 460 4x4 engine swap to I6
