tire size/gear ratio
Old 09-17-2018, 03:20 PM
JonC12345
JonC12345 is offline
JonC12345 is starting off with a positive reputation.
I just purchased a 1990 F250 with a 7.5 motor and auto 4e0d transmission. I live in NY and bought this truck online from Washington State. The truck is lifted 6 inched and has 35 inch tires on it with 4:10 gears. I was admiring this beauty when my son said that it may burn up the transmission trying to pull my 20foot enclosed trailer I use to haul my 1940 Ford pickup to some shows. Then I realized that the tires will change the gear ratio but is it too much?
Old 09-17-2018, 03:25 PM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
Try it and see how it does, also add a trans temp gauge. The 7.5 is a big engine so 35s with 4.10 gears may not be too bad.
Old 09-17-2018, 03:32 PM
JonC12345
What temps should I consider safe
Old 09-17-2018, 03:51 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
I'd suggest adding a trans shift kit, an aux trans fluid cooler and a temp gauge to monitor it. Heat kills an auto trans and these early copies are known for brutally lazy shifts which builds heat and wears out components.
Old 09-17-2018, 05:41 PM
00t444e's Avatar
00t444e
00t444e is offline
220 is about the maximum
Old 09-17-2018, 08:11 PM
Briansshop's Avatar
Briansshop
Briansshop is online now
Briansshop has a good reputation on FTE.Briansshop has a good reputation on FTE.Briansshop has a good reputation on FTE.
I tow with 38s on my f350,I think you'll be fine.
Old 09-18-2018, 07:11 AM
JonC12345
Thanks to everyone for the responses, I don't plan on driving this truck through the NY winters and salt so I will have time to put a gauge on and see this spring. Thanks again Jon
Old 09-18-2018, 09:55 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
Make sure you take the trans out of OD when towing
Old 09-18-2018, 11:55 AM
00t444e's Avatar
00t444e
00t444e is offline
There is no problem with towing in OD as long as it isn't constantly shifting back and forth.
Old 09-18-2018, 08:13 PM
Diesel_Brad
With 35s, that is all it is going to do is shift in and out of OD. So like I said, take it out of OD
Old 09-18-2018, 09:09 PM
00t444e's Avatar
00t444e
00t444e is offline
Going 75 MPH in OD with 35s and 4.10s would put you at about 2100 RPMs, a healthy 460 should be able to tow 6-7K at that RPM on flat land.
Old 09-19-2018, 05:21 AM
Diesel_Brad
Maybe you have never been to NY. There are way more hills than flat land
Old 09-19-2018, 05:54 AM
00t444e's Avatar
00t444e
00t444e is offline
No I have never been there, but I live in the middle of appalachia, plenty of hills around here, the OP didn't state where he lived.
Old 09-19-2018, 06:53 AM
arse_sidewards
arse_sidewards is offline
arse_sidewards is starting off with a positive reputation.
250 on down is fine for a transmission that's working hard so long as you kinda sorta change the fluid on time. Don't worry about the occasional spike to 280 while pulling a hill. High temp primarily affects the longevity of the fluid and rubber components in the trans. You need to get really hot before friction components start to care.
Do you run a 160 tstat and start worrying when it hits 180? There's no harm in running at 220 but it's a stupidly conservative limit for a truck that's working hard.
So then you should know better than to say a 460 truck with 4.10s is only good for 6-7k on flat ground. I wouldn't think twice about putting 6-7k behind my F150 with a 300 in Vermont or New Hampshire.
Old 09-19-2018, 06:59 AM
Briansshop's Avatar
Briansshop
OP did say NY.
Yes, a little common sense. If you're on a grade and the trans is right between 3rd,4th,kick it out of OD. Flat ground leave OD on.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
