460 gas pig?
Any advise would be helpful. Thanks, Trevor.
I think most of the mid 90s 460 trucks with same general equipment as mine get about the same mileage for the same driving conditions. The 350s might get a tad less due to a little more weight.
As far as whether the 300 has enough power, it all depends on what you want to do. If you tow a large trailer, then yes the 460 has plenty of power which the 300 doesn't. If you just want to tootle around town with no load, then maybe the 300 will keep you happy. I think it was an option in the light duty version of the 250 and maybe 350. The 300 is a good torque motor so I have read, while the 460 has plenty of both torque and hp, torque to get you rolling and hp to get you up to speed.
I think that I have read that the 300 in a 250 gets only a little better mileage than the 460. I think it is because of the weight and drive train drag. I might be wrong.
Unless the 460 was a total rag, I would consider keeping it in there. I don't think the 300 will give you enough economy to make up for the hassle of converting. I have never made this conversion so can't speak from experience.
Good Luck,
Jim Henderson
I get about 10-12 mpg's as well in my 86 F-250HD. I have 4.10 gears and if your truck is geared that low as well, you could swap in 3.54 or 3.73 gears to give you some extra mileage. If you do a lot of towing, 4.10's are the ticket. All in all, a 460 is not going to give you very good mileage, but it will get any job done you need it to do.
Tex
Also - big, fat tires have a lot of weight and rolling resistance. In other words monster tires cost you fuel economy. A set of all-terrain, or even highway only, radials are much easier on the gas account.
Install some manual hub locks if your setup will allow it. Driveline parts weigh a lot, so unlocking the front driveline will help keep rotating mass to a minimum when you are not in 4wd. Every little bit helps!
Brad
I've been working on this project for a while, but I'm building a 500cid twin-turbo motor for it, and honestly, I expect the same mileage more or less, when driving gently. Like others have said, the 460 makes significantly more torque to begin with, and way down low in the RPM band, so you can change your differential ratio below what you have to compensate, and you'll have the same mileage.
While not a Ford, I built up a 1975 Dodge D200 extended cab (similar to F250) with a 451 twin turbo stroker, and it hummed nicely at 15mpg when I was gently cruising at 70ish, for this reason. EFI of course. A good blip of the throttle however spoiled potential gas mileage, but that's irrelevent to your point.
You can get decent mileage with a big-block for sure, many of us have done it.
If you want to invest a few dollars and a lot of time, you can replace your existing ECM (computer) with one from a Ford Lightning of similar year if you can find one, and use a program called Tweecer to adjust anything you like, tailoring your ECM data tables to match whatever cam, heads, etc that you choose on your new engine.
