Another aod question
Unlike the kick down rods TV rods have no return spring in the trans and it must be pulled home at the carb. On the lokar set up it is pushed home at the trans with a coil spring around the cable mounting bracket pushing the TV cable arm home... Even kick down rod arms have a return spring but; it's usually a coil spring hooked to the kick down arm and then to the carb or a bracket, it's done this way the same reason there is no room on the throttle shaft to install 3 axial mounted return springs.
Doesn't this [earlier] Motorcraft 2150 with an AOD throttle shaft fit what you are saying can't be done? This style uses a return spring on the TV lever:
With a TV cable, if the cable breaks off or is pulled out of adjustment, the TV pressure would drop to zero, and *that* will destroy the AOD in a hurry.
Right?
I don't see how the AOD could be hurt if the kickdown (or TV) return spring breaks and the TV rod drops to WOT position, like in the picture above. Wouldn't the weight of the TV rod push down on the TV lever, which would give the AOD full TV pressure, and *save* the transmission? (One of the advantages of the TV rod setup compared to a TV cable).
Right?
The AOD seen many revisions throughout it's life the early units 80-81 were the worst. In 82 revisions to line pressures were made and they were marginally better . 83 seen several internal upgrades and this when the AOD started to become a somewhat reliable trans. There were incremental upgrades basically every year the trans was in use till about 91. The a last few years 91-93 were the best of the lot. 80-82 should be avoided altogether as a basis for a build , as pretty much everything in the trans will need to be swapped out. The ones to look for a build basis are the 91-93 units
Okay, so why didn't Ford simply use their existing Motorcraft 2150 carburetors with the Ford kickdown linkage with the AOD? I mean, surely it would have been MUCH cheaper for them to simply design the TV lever on the transmission end to match the longer arc of the Ford kickdown linkage. Right?
Doesn't the carburetor in the picture above have the pump overtravel?
As for Ford not making the TV rod arc radius the same as the kick down or even using the auto kick down lever, no idea why they did not do that there certainly was nothing stopping them from doing it. It may have simply been an idiot proofing measure for tech's and the DIYer, given the similarity to a kickdown rod. This was still in the era when many people still did a lot of the basic maintenance on their vehicles themselves. And not like today where basically nobody does. Back in that era everyone I knew and all of my relatives older than myself did their own basic maintenance, the house hold that did not do basic stuff was an exception ... Now a days the exception is the ones that do , do it themselves... So who really knows why Ford did it the way they did. But I suspect it had something to do with idiot proofing. Cause even today some people think the TV rod does the same thing as a kick down rod... We have even seen that on this forum in from more than one newbie ....
No idea if the carb in the pic has an over travel or not and I can not recall if the early style AOD carbs had them or not, it has been over 30 years since I handled one. As the early AOD's could not really handle any increases in power at all.
But just because it has the deep accel pump cover does not automatically make it an over travel accel pump as Ford used this style of cover in some non over travel applications just with a longer plunger rod on the accel pump.
In the later AOD carbs the Accel pump and the TV rod were on the same lever so that lever had to full stroke with the throttle and that was too much movement for the old style accel pumps so an over travel was needed. They also used the over travel pumps in some non AOD applications where the accel pump lever was fixed to the throttle shaft since the accel pump lever full stroked like the AOD's it also needed an over travel accel pump.
See below pic of an over travel accel pump diaphragm. There is a another piece not shown the cup/sleeve that sits over the pump rod and in to the cup the retains the spring and it acted upon buy the pump lever... When the pump diaphragm bottoms out the rest of the travel/stroke is taken up in the spring as the sleeve moves down the pump rod. So the accel pump rod over travels the movement of the pump diaphragm.
There are so many variations of the 2150 carb especially in the early 80's it is mind boggling. and I'm sure you could find any variation you can think of if you looked long enough.
