85 windsor ballast resistor problem
Old Sep 14, 2018 | 06:16 PM
telefunkken's Avatar
telefunkken
parts store sez this part (ballast resistor) is no longer avialiable,engine is duraspark, with carb. is there another resistor like the ceramic one dodge used I could go with. also what is the correct ohms resistence for this stock coil. I"ll hit the junkyard but I"d rather get a new one
Old Sep 14, 2018 | 06:40 PM
Franklin2's Avatar
Franklin2
In 85 they did not have a "resistor" they had a resistance wire. A special wire made into the harness. You did not say what the problem is and why you need this resistor, usually it's because of a retro fit into another vehicle. The factory resistance wire rarely gives any problems. The resistance spec is 1.05 to 1.15 ohms. I have recommended Chrysler resistors before, and people have had good results with those. Chrysler used the ceramic resistor more often than the resistance wire. Advance Auto has a ceramic resistor part number RU4 made by BWD. The spec on it is .75 to 1.5 ohms. As long as you are in the ballpark it should work ok.
Old Sep 15, 2018 | 09:20 AM
telefunkken
thank you franklin2 and yes it is a retro fit(56 pickup) I should of mentioned that. I will go get that part today and thanks for the spec numbers
xlhr8r
Sep 9, 2015 02:41 AM
bob hare
Electrical Systems/Wiring
Dec 3, 2005 11:59 PM
bivens1172
Apr 27, 2005 12:17 AM
mamafedmepaintchips
Nov 28, 2003 02:34 PM
