2008 f250 trans wiring diagram
Excellent, got it, my connector came apart when the driveshaft/transfer wiped itself out!!!!!, it wasn't going into OD, ended up I did get the wires in the correct sequence, the real problem which I just found out was a cut wire in the POS GM style plastic loom, got it going now. Thanks for your help. Now I have to figure out why the batt/charge light is on, almost think it came on after I washed the engine area, not sure as I just got the truck with the exploded transfer case that the last owner had the privilege to experience, must have been quite the mess as there was only about a 1/4 of the transfer case left, LOL!!!
02sd
09-18-2018 02:39 PM
Caper10
02-08-2005 05:26 AM
