Resistor wire for engine swap?
Old Aug 21, 2015 | 12:21 AM
xlhr8r's Avatar
xlhr8r
Hi, putting a '73 4.9L engine in an '83 f250. Want to know if I need to use a resistor wire for coil. Using complete '73, carb, dist, coil, etc.. Any info will be helpful. Thanks...
Old Aug 21, 2015 | 05:31 AM
roadrash63's Avatar
roadrash63
Yes
You will need a resistor or resistor wire while the ignition switch is in the run position.you can buy the wire with the resistor built in (dont shorten) or
You can do what i did use a ceramic resistor like for a 55 chevy or dodge used them in the 70's.just wire it in and mount.
Old Aug 21, 2015 | 12:12 PM
Gary Lewis's Avatar
Gary Lewis
But, unless the 83 was a diesel a resistor wire is built in to the harness.
Old Aug 21, 2015 | 12:16 PM
Jagesage's Avatar
Jagesage
The coil's are different, so where it is built in, is a different set up
Old Aug 21, 2015 | 12:21 PM
Gary Lewis's Avatar
Gary Lewis
If you use the factory coil wiring there is a resistor built in. To use a separate one will require separate wiring. And there is no reason I can see to do that.
Old Aug 21, 2015 | 12:26 PM
1986F150six's Avatar
1986F150six
Please excuse the Hijack...
Gary, have you checked your PM box?
Old Aug 21, 2015 | 12:29 PM
JimsRebel's Avatar
JimsRebel
Does the 1973 use a point dist.
Old Aug 21, 2015 | 12:53 PM
Gary Lewis's Avatar
Gary Lewis
Have now and have responded. Thanks! Hijack over.
Old Sep 9, 2015 | 02:33 AM
xlhr8r's Avatar
xlhr8r
Better late than...
Hey, thanks. Just been real bz. Just wondering if you know if i can just use the '83 electronic distributor. I just bought a new one while i was trying to figure out what is wrong with '83. I'd rather use the '83 ignition, at least for now. I'm just too caught up in other things to fool around with changes.
Thanks again for the response.
Old Sep 9, 2015 | 02:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The resistor wire is already present.
D7AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY 213) / Obsolete ~ Available NOS & from auto parts stores.
49" long / Color coded red with green stripes / 1.30-1.40 ohms resistance / #16 gauge wire.
Applications: 1977/89 F100/350, Bronco & Econoline.
DuraSpark electronic ignition introduced in 1974, but not all vehicles came with it until 1976.
672wd72highboy
Jun 18, 2014 06:53 PM
eficat
Jul 29, 2011 09:00 PM
bivens1172
Apr 27, 2005 12:17 AM
Scouder
May 17, 2002 04:49 PM
