e4od interchange
Old Sep 14, 2018 | 05:54 PM
2020's Avatar
2020
e4od interchange
I've been told I can't use an earlier model year e4od trans in my 1995 f150. I thought any 92-96 e4od with a small block bellhousing would work. Anybody have any info on e4od interchange?
Old Sep 15, 2018 | 02:03 AM
Fordication's Avatar
Fordication
Do not go that way. If you chose go forward. All E4OD's can be upgraded at a reasonable cost to offset any idea to go backwards. In fact any rebuild by a reputable transmission guy will upgrade your transmission to better than new.
Old Sep 15, 2018 | 05:29 AM
2020's Avatar
2020
I have found a couple of transmissions in the $100 - $200 range and it's just an old farm/wood truck. I hate to spend half the truck's value on a rebuild.
Old Sep 15, 2018 | 07:08 AM
Briansshop's Avatar
Briansshop
The newer yrs are better. There's also a change in the valve body wiring harness in the earlier yrs,don't rem exactly, but using would require changing the harness or VB.
Old Sep 15, 2018 | 09:20 AM
2020's Avatar
2020
I've heard the solenoid pack harness can be re-pinned to work with the pre-95 trans. I was hoping one of the experienced members here would have more info.
Old Sep 15, 2018 | 09:23 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Is that the lightning in your sig? Shame to use a sports truck as a farm truck.Someone would probably like to have one to restore.
You can use the older trans,just make sure you use your newer ('95+) solenoid pack.The diesels changed between a 4 stud and a 6 stud converter but with the gas engines,I think they're all the same.
$100-$200 is core price for an E4OD.At least the diesel ones.If you can find any working in that price range,that's even cheaper than an old used C6!
You could use one of those old 3 speeds too if you wanted for a farm truck.You'd need much more modifications than just swapping out a solenoid pack,such as cross member,driveshaft length,a manual shift ECM swap, etc. but if you can get a working E4OD for C6 price,your golden.I do hope this isn't a lightning though.
Old Sep 15, 2018 | 09:38 AM
2020's Avatar
2020
No, the Lightning in the sig is my one owner 20,000 mile garage queen LOL. I picked up an old 95 4wd f150 that I don't want to put a $1k rebuilt trans in.
Old Sep 15, 2018 | 09:41 AM
FORDF250HDXLT
Oh that's good to hear.Yeah whatever you can find for the old woods truck. You don't need to buy the solenoid pack either,just use the one in your old trans.Just don't forget you'll need a 4wd version trans.
Old Sep 15, 2018 | 10:23 AM
2020's Avatar
2020
I've heard the plug needs re-pinned and also heard that the solenoid pack would need changed.
Old Sep 15, 2018 | 12:31 PM
FORDF250HDXLT
Yeah no point in messing with that.You already have one in your old trans,it's right there under the pan and swaps out super easy so.
10strokin
21
Oct 27, 2015 11:18 AM
hav24wheel
Oct 28, 2010 07:46 AM
optimist199
May 21, 2004 04:24 PM
UPBronc
May 3, 2003 04:25 PM
