P0667 trouble code
Old Nov 6, 2018 | 10:37 AM
bismic's Avatar
bismic
I believe you could always use the shorter, later model glow plug to be safe.
I don't think there was a change in the depth of the GP well in the heads over the years. The 2003 piston is unique and by that situation is an expensive piston to install when rebuilding motors. If you have an MY 2003 rebuilt, it could have either piston in it depending on the source.
Agreed. My concern is "not getting" what you ordered/needed on Amazon or in a parts store
Old Nov 6, 2018 | 03:56 PM
Yahiko's Avatar
Yahiko
[ Rant = On ]
Amazon just did that to me on something I ordered from EBAY. Two things get under my skin on that one. I ordered from a EBAY seller
and they used Amazon so how much did that add to the cost and the second part they sent the wrong item and now I have to send it back
and wait to get my $ back. How hard is it to pull the right set of sheets for a bed off a shelf?
I find that only if I can't get the item from a local store tor Ebay then I look to see if I can find it some other place before I use Amazon.
[ /Rant = off ]
Old Nov 10, 2018 | 11:23 AM
Shiloh51933's Avatar
Shiloh51933
Originally Posted by Yahiko
Amazon is also good for killing small stores. I try to buy local first if I can.
I agree...I refuse to buy Amazon and there attempt to monopolize the retail industry.
Old Nov 10, 2018 | 11:34 AM
Shiloh51933
Getting ready for glow plug swap.
Yesterday my #2 glow plug set DTC, so I'm planning on doing all 4 on that side for now. So I bought 4 GP's from Riverhead Ford, NY (4C3Z-12A342-AA). I priced the driver side harness while I was there but it was pricey and I just didn't have it to spend yesterday. Anyway I went on XDP website and found the driver side harness made by Bostech (WHO2960) $39.95. Does anyone know who makes the Glow plug harness for Ford or has anyone used a Bostech harness on there 6.0l?
Old Nov 10, 2018 | 11:51 AM
bismic's Avatar
bismic
$47 at AutoNation White Bear Lake
https://parts.autonationfordwhitebea...sy-5c3z12a690a
or $49 at Tasca
https://www.tascaparts.com/oem-parts...iABEgLzFfD_BwE
Old Nov 10, 2018 | 01:15 PM
Shiloh51933
Originally Posted by bismic
Wow...thank you for posting these links. I'd hate to do this job and not replace the harness especially since they get fragile after 10 years of wear/tear.
Old Nov 10, 2018 | 01:46 PM
Yahiko's Avatar
Yahiko
Don't forget >>> FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
Same Ford part and should be less than AutoNation White Bear Lake.
Ed at FICMrepair supports FTE and AutoNation no longer does.
Old Nov 10, 2018 | 02:52 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by TooManyToys.;18290556[color=#c0392b
]I believe you could always use the shorter, later model glow plug to be safe[/color].
You are correct. I've got 03 pistons with the shorter, later model glowplugs and haven't had any issues at all. There wasn't a change in the depth of the GP well it was a change in the piston bowl that necessitated the shorter glow plugs.
Old Nov 10, 2018 | 04:23 PM
TooManyToys.'s Avatar
TooManyToys.
An easy check to make Sean.
Old Nov 11, 2018 | 09:09 AM
Shiloh51933
Is there anything else I need besides the glow plugs, hareness and hareness plug tool that I should know about b4 I get into this?
Old Nov 11, 2018 | 09:41 AM
TooManyToys.
The way I would do this is a PITA, but .....
Remove the valve covers and plug the oil drain back holes in the head that would allow broken parts of the harness connector to fall into the oil pan. While the plastic would be easily digestible by the LPOP, it’s something I would personally prefer to avoid.
It was interesting when I pulled the harness connectors out of my ‘03 motor while it was on the stand in the garage. The rebuilt motor installed by the dealer in 2010 had a newer harness on the one side and a very rusted original harness on the other. The orginal to truck older harness popped out fine, totally intact. The Ford installed 2010 harness broke all apart despite having the pulling tool and the most ideal conditions for removing the harness. However, since that one side was replaced during the motor swap, maybe it’s more of a tail of one side gets a little more heat then the other rather then a lowering of quality with a different “OE” Ford supplier.
adammdennis11
Apr 11, 2014 02:19 PM
jereli
Jan 31, 2014 10:34 PM
jayhawk714
Jun 27, 2013 06:40 PM
VegiePower
Dec 18, 2012 10:54 PM
