2.5L 2WD automatic - Went to work this morning no problems, at the end of the day ready to leave and truck would not start. Appears battery is fine all accessories radio lights working etc.. turn ignition and and one click but engine does not turn over. First thought is starter solenoid. Does that sound right? Is there anything I should do before I pull the starter? Thanks
You should check all fuses/relays associated with the starting system and ignition system first. Look in your 2000 Ranger Owners Manual under the "Roadside Emergencies" section for diagrams and descriptions of the fuse/relays in the Passenger Compartment fuse panel, as well as the Power Distribution Box located under the hood.
If you want the long version of testing automotive relays, then do an internet search, there are some very good videos on that subject. My way of testing them is to swap in another relay that is known to be good.
You mentioned you checked the starting system fuses, how about those associated with the ignition system?
Another thing to think about is the ignition switch itself...sometimes they can fail at the key/column area. Have you tried starting it in neutral?
I can't recall right now if our vintage Rangers have a stand-alone starter solenoid, or if the solenoid is integral to the starter itself...hopefully someone will chime in and confirm.
I tried to start in neutral and no dice. Assume same result in neutral means ignition switch is ok (switch in column)?
I am leaning towards pulling starter and taking to Advanced Auto. Any reason it could not be the starter? The single click is still there.
Plug in your ELM scantool into the in cabin DLC port & running FORScan diagnostic freeware on the viewing device of your choice as discussed here https://www.ford-trucks.com/forums/1...-scantool.html, as its tweaked for Fords & can scan All of the onboard computer/controllers, including the PATS anti-theft system for trouble code clues that can help focus a trouble shoot, then post All code Numbers.
For no cost Wiring & TSB info, enter your vehicle particulars & click on wiring diagrams here BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
As Rockledge suggested, check the starter relay as they are a common problem part. It's in the under hood battery junction box, driver side, back against the firewall/fender location. Give the relay a wiggle/thump test to see if it'll wake up, or swap it with a known good relay as Rockledge suggested.
If still no joy, perform a wiggle test on the wiring to the starter motor & or give it a thump test with a piece of wood & see if it'll wake up.
More trouble shooting thoughts for consideration, let us know what you find.
Thank you Pawpaw - BBB Industries wiring diagrams are very helpful! Fuses checked SAT (Starter), don't know how to check the starter relay, but power must be getting down to the starter (assuming the click that I hear is the starter engaging just not turning).
If you can feel the starter solenoid pulling in, then thump the starter motor with a piece of wood & see if it'll wake up & run. If so, suspect the solenoid high amp contacts that run the starter motor are eroded & making poor contact, or maybe worn starter motor brushes, or starter motor commutator is worn, if a thump will make it wake up & run.
As Rockledge suggested, check the starter relay as they are common problem parts. It's in the under hood battery junction box, driver side, back against the firewall/fender location. Give the relay a wiggle/thump test to see if it'll wake up, or swap it with a known good relay as Rockledge suggested.
I found the starter relay yesterday and pulled it out and put it back in, wiggled it and still no crank. Also it is not like what I remember it looking like (pic above) In reference to what Rockledge said about swapping with a known good relay are there any other relays in the battery junction box that are identical to this one that I can swap? I thought there was another relay that looked like the starter relay?
