Engine code P0402 2012 F250 6.7
Old Sep 11, 2018 | 06:25 PM
Shane Ryan's Avatar
Shane Ryan
I have a 2012 F250 with a 6.7. Was throwing P0401. The dealer told me to replace the EGR valve. Replaced the valve and cleared code. 40 miles down the road P0402 shows up. Ive replaced air filter, EGR valve MAF and cant figure this one out. Has anyone else had luck with this code?
Old Sep 11, 2018 | 07:00 PM
senix's Avatar
senix
EGR cooler needs cleaned or replaced, not the valve.
You can clean the cooler with some soap and water and then blow it out.
Old Sep 11, 2018 | 07:18 PM
Shane Ryan's Avatar
Shane Ryan
P0402
Have you seen this code before?
Old Sep 11, 2018 | 07:23 PM
senix's Avatar
senix
See the TSB
File Type: pdf
Old Sep 11, 2018 | 07:24 PM
senix's Avatar
senix
TSB says to replace the core. But you can clean it and reuse it.
Old Sep 11, 2018 | 07:28 PM
Shane Ryan's Avatar
Shane Ryan
Different code.
That’s for a p0401 not a p0402.
Old Sep 11, 2018 | 07:32 PM
senix's Avatar
senix
sorry about that! should have paid closer attention to your code. certainly EGR related. Id probably have a look and do some pin point testing of the valve.
Old Sep 11, 2018 | 07:36 PM
Shane Ryan's Avatar
Shane Ryan
All good lol.
Old Sep 11, 2018 | 07:49 PM
kper05's Avatar
kper05
Plugged EGR cooler for P0401. P0402 is a code for a flow issue so I am fairly certain it can be related to blockage.
Old Sep 11, 2018 | 07:50 PM
senix's Avatar
senix
only thing I can really come up with is your original code that would have directed you to check the core. Otherwise you have addressed everything else it could have been.
Old Sep 11, 2018 | 07:52 PM
kper05's Avatar
kper05
There is a MAP sensor as well but I don't think that is the issue here.
Old Sep 11, 2018 | 08:28 PM
Shane Ryan's Avatar
Shane Ryan
p0402 is for excessive flow. Wouldn’t the blockage reduce the flow.
Old Sep 12, 2018 | 05:07 AM
kper05's Avatar
kper05
You have a point, I was thinking restriction but if exhaust gases are bypassing the cooler more then the parameters allow, I could argue that is excessive flow.
What about the EGR pressure sensor?
https://parts.autonationfordwhitebea...sor-bc3z9j460c
billneal
1997 - 2003 F150
19
Oct 22, 2024 10:31 AM
EMC V10 X
Nov 19, 2014 05:19 PM
dvrjump
Apr 12, 2014 12:57 PM
Steadyman321
Jan 26, 2013 12:17 PM
daw1264
1997 - 2003 F150
Feb 7, 2002 07:30 PM
