P0299 code
Old Jan 25, 2013 | 06:07 PM
Steadyman321's Avatar
Steadyman321
P0299 code
One month ago my egr valve got stuck open, I cleaned it and truck runs fine. Two days ago I started my truck (-35 degrees outside) and the P0299 code came on. At idle the VGT is around 65-72 and driving it it is between 43-60. I haven't had a chance to check the upper and lower charger cooler hoses.
Even if I find a cracked hose should I still pull out the turbo and clean everything? Truck is running strong and I've put on 190 miles after the code popped up.
Thanks for reading this and any advise you may make
Old Jan 25, 2013 | 09:54 PM
BLADE35's Avatar
BLADE35
Check and Post
BARO
MAP
EBP
Post those Sensor values at KOEO
KOEO= Key On Engine Off
Old Jan 26, 2013 | 07:06 AM
Steadyman321
My baro is 14.5
Map is 29.6
And my ebp is 15
I also took off my upper and lower charger cooler hoses and the upper is cracked in three different spots
Old Jan 26, 2013 | 09:07 AM
Regulator1988's Avatar
Regulator1988
I had the same code pop up on mine! My egr valve o rings were pretty shot. Do you have an egr delete or anything? If not it may be time for a new valve
Old Jan 26, 2013 | 10:33 AM
cheezit's Avatar
cheezit
check you map calc.
it should be very close to ebp,baro.
if your set up using hg" your reading are correct if not you map is bad
Old Jan 26, 2013 | 11:56 AM
Steadyman321
On Wednesday I cleared the code and it came right back on, today I replace the upper charger cooler hose and cleared the code again and drove around for half an hour and the code hasn't been back yet. I just put on new o-rings on the egr last weekend. Do I need a new manifold or how do I go about replacing the map valve?
Old Jan 26, 2013 | 12:10 PM
cheezit's Avatar
cheezit
the map is a sensor. i would start by checking if the reading is in psi first. then if you are using a scangauge make sure you have the value for the calc right. it looks like it may be set in hg" to me
Old Jan 26, 2013 | 12:17 PM
Steadyman321
I feel like I'm in over my head! I do use the scangauge, and I think you're right about it being psi because when I had to enter all the "codes" into it they suggested I named the setting psi.
Shane Ryan
6.7L Power Stroke Diesel
Sep 12, 2018 05:07 AM
i eat hybrids
May 20, 2017 10:15 PM
dvrjump
Apr 12, 2014 12:57 PM
TheWhiteBeast
Jan 24, 2012 09:42 PM
gb'sfx4
Jun 27, 2010 09:36 PM
