Sync not working
Old Sep 8, 2018 | 04:40 PM
Philip Saraiva's Avatar
Philip Saraiva
Sync not working
Hello! I went to press the Sync button and it isn’t working. Is there a way to reset it?
Old Sep 8, 2018 | 10:51 PM
mxer0022's Avatar
mxer0022
Are you talking about the button on the steering wheel?
Old Sep 9, 2018 | 05:59 AM
Philip Saraiva
yes the button on the steering wheel. When you press the button you are supposed to hear the Sync lady speak. It doesn’t do that anymore.
Old Sep 9, 2018 | 11:22 AM
mxer0022's Avatar
mxer0022
Do the other buttons work on the steering wheel?
Old Sep 10, 2018 | 07:27 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Mine stopped working twice. I pulled the battery cables, someone else posted that they pulled the fuse to the entertainment center. I'll probably go the fuse route next time, with the truck off and the key out of the ignition pull the fuse, wait a minute, put it back in and give it a shot. If that doesn't work I would go the battery route. Remember your entertainment center is a computer that runs an operating system named Sync which is written by Microsoft. A reboot usually solves the problem.
Old Sep 10, 2018 | 08:18 AM
HRTKD's Avatar
HRTKD
There is a master reset for Sync. It's in the menu.
Old Sep 10, 2018 | 12:09 PM
L3dford's Avatar
L3dford
It's actually called Windows Embedded Automotive 7. Hence the need to reboot it sometimes. Every once in a while my radio will lock up so I'll pull the fuse, put it back in and all is good again.
Old Sep 10, 2018 | 04:24 PM
sullyt28's Avatar
sullyt28
It seems like apple carplay and Sync are constantly trying to fight one another. The screens jump back and forth. Now the sync doesn't work as OP mentioned.
Going to pull the fuse and see what happens.
Old Sep 11, 2018 | 03:03 PM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Talking
Thanks, I'll keep that in mind
winginit
Jan 24, 2014 11:27 AM
tdmiller1965
6.7L Power Stroke Diesel
Jul 30, 2012 10:34 AM
PITS
Jun 20, 2012 01:38 PM
sandjunkie
Jun 15, 2005 04:33 PM
