NAV/phone question
Old Jun 20, 2012 | 12:05 PM
PITS's Avatar
PITS
NAV/phone question
Not sure if this is speciific to iPhone or not but...
When I make a call through the NAV unit, when the call is finished and I want to hang up, I cannot do it with the steering wheel buttons. If I hit the off hook button, it gives me a call or redial option only. I have to reach over and push the end button on the display (which should be a lot bigger and away from the call button IMO). And then the display just sits on the phone screen until I hit the home button.
Does it work like that for you guys with different phones?
Old Jun 20, 2012 | 12:18 PM
The Hoot's Avatar
The Hoot
That's the same way it works with my BlackBerry. I thought it was a BB thing....would be nice if they could fix it with a future firmware update.
Hoot
Old Jun 20, 2012 | 12:25 PM
Andrew010's Avatar
Andrew010
Same here - Android phone.
Old Jun 20, 2012 | 12:37 PM
darren32's Avatar
darren32
You need to push and HOLD the button on the steering wheel, then it will hang up.
Thanks
Old Jun 20, 2012 | 12:57 PM
The Hoot's Avatar
The Hoot
Really? I could've sworn i tried that and it just re-dialed. Sweet! I'll try it on the way home from work. Thanks Darren!
Hoot
Old Jun 20, 2012 | 01:13 PM
FishingNut's Avatar
FishingNut
Thanks
For a count of at least 3...PITA but my works fine.
Call ringing...press the steering wheel phone button for a second
Hangup...press the steering wheel button for 3-4 secs
Old Jun 20, 2012 | 01:24 PM
darren32's Avatar
darren32
Hoot
It is a PITA but after re-dialing 1,000 people I finally got used to it. Would be nice if just a push would hang up tho, not sure what the thinking was that went into that one
Old Jun 20, 2012 | 01:32 PM
jdadamsjr's Avatar
jdadamsjr
to make sure you don't inadvertently hangup by turning the wheel and hitting the button slightly....
(maybe ) or maybe only English as a second language thinking went into
Old Jun 20, 2012 | 01:38 PM
PITS's Avatar
PITS
Interesting...I will try that although I am not sure how that will work with my Lockpick which also uses press and hold on the phone button to activate.
Hmmmm.
Thanks for the info.
Philip Saraiva
6.7L Power Stroke Diesel
Sep 11, 2018 03:03 PM
wypowersmoke
Jun 8, 2017 09:03 AM
cecilt
Oct 20, 2015 06:19 PM
Adobe 11SD
16
Oct 4, 2014 07:13 AM
winginit
Jan 24, 2014 11:27 AM
