Tailgate won’t open
Old Sep 8, 2018 | 03:50 PM
Flyct's Avatar
Flyct
FTE Community Team
Tailgate won’t open
2017 F350 Lariat. Tailgate won’t open. Pull handle acts as if it’s locked. The tailgate handle free wheels like linkage or something inside the tailgate has come detached.
It’s still under warranty. It scheduled to be traded later this week for a 19 F350 or as soon as the new truck arrives.
Any ideas what to try rather than go to dealer for a fix?
Old Sep 8, 2018 | 03:58 PM
wildcard30's Avatar
wildcard30
Is the truck configured to unlock all doors at the same time or does it take a second press if the fob to do it?
When you unlock all the doors, does the tailgate unlock? You should hear the actuator being activated. It not, the fuse is blown or the actuator is not working.
Since its under warranty I would take it to the dealer.
You can also search in the forum for threads about the tailgate not unlocking. There are several.
Old Sep 8, 2018 | 04:23 PM
ZacharyDKenney's Avatar
ZacharyDKenney
I recently bought a preowned 2018 250 with roughly 28,000 miles on it. Tailgate wouldn't open exactly how you described, dealer said a latch was corroded preventing the tailgate from opening and replaced it. I asked why a truck so new would have a corrosion problem and the guy gave me a classic useless answer. Rest of the truck seems corrosion free so it's hard to say what exactly caused it.
Old Sep 8, 2018 | 04:27 PM
Flyct's Avatar
Flyct
FTE Community Team
When pressing the fob unlock button and the lock button you can clearly hear the solenoid activate in the tailgate.
Old Sep 8, 2018 | 05:13 PM
senix's Avatar
senix
linkage is disconnected. you will have to remove the panel on the back of the tailgate to be able to manually pull the linkage and unlock the gate from the bed.
Since it is under warranty I'd have the dealer do it since there is likely something of a plastic nature that is broke.
Old Sep 8, 2018 | 06:13 PM
Truckie256's Avatar
Truckie256
my '17 250 had same problem. the rod from the handle to the mechanism came off at the plastic clip on the mechanism...as it turned out, the side rods are to be yellow clips and the handle one is a green clip. ( different part numbers) All 3 of mine were yellow and mounted on top of the mechanism. Was faster for me to buy the Green clip at parts counter($5) and mount it under mechanism and set rod back in it, like it should have been. Problem solved.
Old Sep 8, 2018 | 08:16 PM
Flyct's Avatar
Flyct
FTE Community Team
Fortunately this happened after I removed my BakFlip F1 in preparation to trade the truck in. It would have been a real hassle if the BajFlip was still mounted.
Old Sep 15, 2018 | 05:09 PM
Race Red F-250's Avatar
Race Red F-250
New truck....2 weeks old. Tail gate won’t open. Come on FORD!
Old Sep 15, 2018 | 05:34 PM
Truckie256's Avatar
Truckie256
Open panel and check it..or dealer..... Mine had a wrong plastic clip and it was mounted on wrong side of bracket....ordered right clip $5 (cheaper than day at dealer)
I found if it is tried to open with handle and it's locked you can pull rod out of clip, and will not open...but button if u have it should still work
pickerdd
Oct 2, 2025 02:52 PM
Warpburn
Aug 23, 2018 08:29 AM
finnf250
Feb 22, 2017 07:20 AM
msdt-99517
Oct 1, 2016 03:04 PM
trucker41
Jan 29, 2004 05:20 PM
