Hey peeps, so I’m needing to do a column swap and wondering what years and style I can use when I hit the wreckers next week.
I have a 95’ E150 with “NO” tilt or cruise. But has the overdrive button on shifter.
Can I use any style from 92’- 96’ E150/F150 also ?
or
Do I need exact replacement with no tilt and no cruise buttons and such ?
I guess my question really is are the connections and stuff all the same from a tilt column to a non tilt column and one with cruise will still connect but the column will bolt in and connect to existing plugs and things ?
(Quick photo from video of the column I have.
but cruise itself won’t work without more modifications)
Do you know if it matters if it has tilt/cruise options ? Hard to find any wrecked vans where I’m at so was hoping the trucks fit I know where a few of them are.
I’m a Canadian up in Saskatchewan.
i have found a few of that style here but nobody seems to be able to tell me if it will work. Mine “does not have”: Tilt or Cruise and has the airbag and shifter overdrive button.
I should have ours out this weekend and will take it with me and see if the connections and wiring is the same.
Thanks for trying to assist.
Whats wrong with your colum ? There are companys in the US that just specialize in steering colum rebuilding. 1994 e350 doesnt have air bag so it wont work. Steve
