'95 Steering column replacement
Old Jan 29, 2004 | 11:04 PM
Garandag's Avatar
Garandag
After 236,000 miles on my '95 F350, the steering column is about worn out and I thought I would just replace the whole thing. Is this a pretty simple job to do? What should I expect? My truck is an XL with no tilt or cruise. I assume replacing it with a tilt column would be no big deal but I wondered if I found one with cruise and put it in, would my truck then have cruise control or would additional components and wires need to be installed? Thanks for any help you can give me.
James Beaman
Friendswood, TX
Old Jan 30, 2004 | 12:59 PM
donnor's Avatar
donnor
column swap
Yes, you may swap in a tilt column, but would need the underhood servo/amplifier in order to have cruise control. Be sure that your donor truck is a 93 or newer if you want to accomplish the cruise upgrade (since Ford changed from the old vacuum modulated servo to the stepper motor style in '93) & get the underhood components to complete the job. I believe from my review of the Ford Shop Manual & EVTM, as well as checking some non-cruise trucks, that all the other wiring & connections are already on your truck.
Your current steering wheel will work if the one on your donor truck is trash, but you will need the horn pad with the cruise buttons in it. Does your truck have a manual or automatic tranny? It will be easiest if your donor is the same, but if not you can cannibalize from your original column to modify your new one. This makes a bit more work, but it can be done.
dn.
Old Jan 30, 2004 | 04:22 PM
Home Solutions's Avatar
Home Solutions
I just replaced the column in my 95 F350. It had no tilt, air bag, or cruise. It is about a 2 hours job. Extremely easy to do. You need to remove the plastic shroud just below the steering wheel. Remove the lower filler pael below the column. Loosen the bolt that holds the column to the square key coming out of the firewall. Remove the 4 nuts holding the colum in place. Disconnect the wiring harness in 2 places and slide the column down and out. Reverse for installation.
Good Luck
John
Old Feb 3, 2004 | 09:21 PM
Garandag's Avatar
Garandag
I just now got around to checking back on this. Thanks for the information. That is just what I was looking for. Now to find a replacement column.
James
Old Sep 18, 2005 | 10:55 PM
TEEJAY's Avatar
TEEJAY
What has to be done with the shifter cable? I changed a column before, but there was a floor shifter so I didn't have to worry about it.
Thanks
Dasher400
16
Aug 28, 2016 08:02 PM
mattsautobody442
Dec 12, 2015 06:32 AM
mybadford
WTB - Ford Trucks & other vehicles
Jun 25, 2015 09:15 PM
Econo4spd
Mar 4, 2015 12:49 AM
