Steering column interchange.
Old Mar 13, 2017 | 06:57 PM
fordka's Avatar
fordka
Got a 95 f350 standard with cruise. The prev owner put a 94-96 f150 column in with air bag and no cruise. I got a 93 f150 column with cruise and no air bag like the the same set up it originally had. Will all the plugs and such of the 93 f150 column match up and work in my 95 350 or would i have to change ****.
Old Mar 14, 2017 | 09:07 AM
Red97350's Avatar
Red97350
I believe you should be all set to switch them out. Hope this helps.
Red
Old Mar 14, 2017 | 09:37 AM
78 PEB's Avatar
78 PEB
Even if things don't match up.......everything is easy to swap over once the column is out on the bench..............
Old Sep 24, 2021 | 05:41 PM
sknarf1960's Avatar
sknarf1960
Steering column nterchange question
I’ve got a 96 f250 Powerstroke diesel with a manual trans……I understand that I can take the steering column from a 93 f150 gasser that I have and switch out the entire column,is this correct ..?? Thanks
ace5107
Feb 24, 2024 12:02 PM
Bootlegger's Deluxe
Apr 22, 2018 11:01 PM
garyed08
Dec 6, 2010 07:30 PM
RobPStroker
Jun 27, 2009 08:42 PM
Garandag
Sep 18, 2005 10:55 PM
