Sponsored by: Real Truck
Code P207F & P229F
Old Sep 2, 2018 | 01:34 PM
livetoridebobshd's Avatar
livetoridebobshd
Angry Code P207F & P229F
PI just had my local Ford dealer replace a OIL/AIR SEPARATOR. SEPARATOR. SEPARATOR ASY - OIL. on my 2015 F-250. The Engine light had came on so I took it to the dealer. Pick it up the next day. It was covered under Fords Field Service Actions 17M04.. I drove it a few miles and the light came back on. I can see where they replaced the part. Today I went to AutoZone and had them hook it up and Code P207F came up,The way that I am reading what I can find online is that Code P207F is covered by Field Service Actions 15M02. On my way back home I saw that the light was out, so I called AutoZone and asked if they had cleared the code they said NO. So I went back to AutoZone and they ran the codes again and two code came up this time. P207F & P229F. Please help me what is going on. Is Code P229F covered by and Field Service Action?
Old Sep 2, 2018 | 02:06 PM
Just Strokin's Avatar
Just Strokin
It should be covered under the latest FSA for the CCV. Contact your locale Ford dealer and repair should be at not cost.
Old Sep 2, 2018 | 02:12 PM
livetoridebobshd
So you think that both of the codes P207F and P229F should be covered at no cost. I can't seem to find much on code P229F.
Old Sep 2, 2018 | 03:48 PM
Evan_P's Avatar
Evan_P
Those codes are for issues in the Exhaust emissions components. Neither will be covered under 15M02, which is an extended coverage for EGT sensors, or 17M04, extended coverage on the CCV separator.
Old Sep 2, 2018 | 05:40 PM
Just Strokin
P229F NOx Sensor Circuit Range/Performance (Bank 1 Sensor 2)
NOx Catalyst 6.7L V8: P20EE P207F
P207F – Reductant Quality Performance
This problem may be covered under the FSA - Field Service Action Number: 18M01
Title: REDUCTANT HEATER AND SENDER ASSEMBLY REPAIR
mustangmford
2009 - 2014 F150
Nov 21, 2017 10:56 PM
bkuuz1
6.7L Power Stroke Diesel
Oct 13, 2016 08:24 AM
fixit5561
Aug 23, 2010 04:17 PM
eric777
Sep 18, 2006 06:55 PM
greystreak92
1978 - 1996 Big Bronco
Apr 25, 2003 02:40 AM
