CEL Questions?
Old Oct 13, 2016 | 07:04 AM
bkuuz1's Avatar
bkuuz1
CEL Questions?
When you get a CEL light is it locked in until it is reset with a code reader?
Do certain codes cause the CEL to be locked in (hard code alarm) and others cause a CEL but once cleared (soft code alarm) on their own allow the CEL to clear on a engine restart for example?
For example, A couple of days I had the CEL light come on. When I checked the codes using TP, I had 2 codes showing in the registry. A P0170 Powertrain cel Trim (Bank 1) , which has come up a few times before. And a new one P04DB Powertrain, which to my understanding is a (Crank Case Over Pressure).
While moving my truck around in the drive a couple of times the CEL light was ON. Last night when I went out to move the truck again the CEL light was OFF. I haven't ran a code check on it yet to see if the two codes are still showing in the bank list or not.
Thats why I wondering if/when you get a code and a CEL light locks on (hard lock) or when condition clears CEL light off (Soft) alarm.
I have an appointment for in to go in under warranty on Monday but I know from the last time it went in that if it doesn't through the codes again after they reset them the dealer really won't do anything.
Old Oct 13, 2016 | 07:37 AM
Just Strokin's Avatar
Just Strokin
Some CEL's can be cleared by the ECM/PCM when you have the correct drive cycle sequences and the problem does not reappear.
Old Oct 13, 2016 | 08:08 AM
JohnD333's Avatar
JohnD333
BK...
My P0170 Code "fuel trim bank..." came on about every 1,000 miles, and light would turn itself off in about 8 key recycles. It remained stored in memory for a while. Came on at engine startup on each occasion.
Search P0170 on this forum.
Lots of pin tests- unsuccessful- nothing found. I did replace both air filters (not dirty), but no help. Then a bad injector found, but still that code and light every 1,000 miles. This went on for 8k miles. Finally dealer said Ford knows of code problem; no solution, just drive and reset (first verify code, then reset with my TorquePro). Got Re-flash months later. This was before the dual-bank Re flash came out. No codes since then. (10k miles).
I know nothing about your other code.
Old Oct 13, 2016 | 08:24 AM
bkuuz1's Avatar
bkuuz1
Thanks for the info.
JohnD333, I have another thread running about the the P0170 code on FTE. It pops every now then. I'm thinking the prom is the computer needs a set condition with a timer attached to it. More then likely it just has to short of a duration. We see this all the time in control logics with process.
homerj
Apr 16, 2019 07:56 PM
jaagen
Oct 8, 2012 02:57 PM
5.4L to Freedom
Apr 13, 2010 10:42 AM
F450 Aaron
Aug 8, 2007 04:04 PM
Jim59
Oct 21, 2005 05:07 PM
