Sponsored by: Real Truck
2010 f250 Keyless entry passcode?
Old Aug 31, 2018 | 12:02 AM
Adan_Reyes's Avatar
Adan_Reyes
I bought my truck in February this year 2010 f250 king ranch 4x4 6.4l. I was wondering where i could reset the code for key less entry. I heard about being able to reset it by using the original code but i cant seem to find it anywhere, any suggestions on where to look for it? or would i have to go to the dealer?
Old Aug 31, 2018 | 03:39 AM
seville009's Avatar
seville009
Old Aug 31, 2018 | 06:12 AM
Lariatstang's Avatar
Lariatstang
Retrieving keycode
If you don’t have your owners manual with the factory key code you may be able to retrieve it through your trucks on board diag system. This worked for my 2015, it’s worth a try in your truck.
You will need 2 sets of ignition keys. Take your main key and turn the ignition to the “on” position but do not start the truck. Wait a few seconds and most of your dash lights will go out (a couple may stay on) I forget the exact timing but it should only be a couple of seconds. Then take that key out and immediately put your other key in the ignition and do the same thing. (do not start the truck) Your “factory door code” should come up on the info center of your gauge cluster.
Just use this code to reset your door to whatever you want.
Old Aug 31, 2018 | 07:02 AM
SnowPlowDriver's Avatar
SnowPlowDriver
The code on my 2011 is on a wiring loom plugged into the bcm in the passenger side kick panel.
deputypq920
2009 - 2014 F150
18
Dec 16, 2021 12:04 AM
island eddie
Nov 6, 2017 11:08 AM
mc1502
2009 - 2014 F150
Jul 3, 2015 03:33 PM
OutlawNomad
Aug 6, 2011 05:05 AM
