Key Pad Under Handle
Old Jul 2, 2015 | 11:11 AM
mc1502's Avatar
mc1502
My new truck (2014 Lariat) has the number keypad under the driver's door handle. Is the factor code for this printed anywhere? The dealership didn't tell me how to use it when I took delivery.
Old Jul 2, 2015 | 12:47 PM
PrinceValium's Avatar
PrinceValium
There is usually a card that comes with the owners manuals that has the factory code printed on it. Here is an easy way to get the code if you have two key fobs on your truck. The instructions below basically mean having two key fobs that are programmed for your truck.
Displaying the Factory Set Code
With Integrated Keyhead Transmitters
You will need to have two programmed passive anti-theft keys for this procedure. To display the factory-set code in the information display:
Insert a key into the ignition and switch the ignition on for a few seconds.
Switch the ignition off and remove the key.
Insert the second key into the ignition and switch the ignition on.
The factory-set code will display for a few seconds. It may not display until after other warning messages have displayed first.
Just an FYI you don't want anyone to know this code. It is a factory code that can be used at any time just in case you forget the codes you have previously entered.
Hope this helps.
Old Jul 2, 2015 | 02:47 PM
Olytlr's Avatar
Olytlr
If you don't have the card with your vehicle info there is another way to find it.
At least on my 2012 it is printed on the fuse module hidden behind the passenger side lower kick panel. If you pull the kick panel and grab a flashlight you can't miss it. The numbers are fairly big and in plain sight.
Old Jul 3, 2015 | 07:35 AM
PrinceValium
This is what Olytir was referring to, a LOT more work than just using the two key fobs!:
Old Jul 3, 2015 | 03:33 PM
Frantz's Avatar
Frantz
As mentioned, you should have a credit card sized instruction plastic card that's white with the 5 digit code. You can read owners manual to see how to make custom codes but you need the factory code to do so. The dealership can pull the code, so if the card is missing have them do this for you free of charge (since you just bought it an all).
bubbasz1
Aug 13, 2019 04:45 AM
Rogue427
Jan 2, 2019 05:12 AM
wmcneil
2015 + Expedition & Navigator
Jan 7, 2017 06:26 AM
edlinfir24
Transit Connect
Dec 21, 2016 01:49 PM
KJ Smith
2009 - 2014 F150
Jan 7, 2014 08:01 PM
