2001 Ford e350 Over Drive switch not working
Old Sep 4, 2018 | 10:49 AM
Derick6505's Avatar
Derick6505
Anyone? Is there anyway to bypass the pcm and send a signal to the transmission manually? Maybe run a momentary switch inbetween the hot on the fuse box and the to the transmission where the pcm sends the signal?
I’m starting to believe it might be the PCM but again it’s almost impossible to find any good data on what voltages I should be seeing and all that.
I have no codes and nothing else seems to be affected.
Thanks again.
Old Sep 4, 2018 | 01:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What signal are you trying to send to the transmission? It doesn't get a signal that OD is turned off. The PCM just turns the two shift solenoids on and off, which creates four gear ratios. SS1 on/SS2 off is first gear, both on is second gear, SS1 off/SS2 on is third gear, and both off is fourth gear. When you press the OD OFF button the PCM doesn't allow a shift to fourth gear by not turning off both solenoids.
Old Sep 4, 2018 | 02:27 PM
Derick6505's Avatar
Derick6505
Thanks for clearing that up
Is there any way then to send a signal to the solenoid bypassing the pcm?
Basically all im asking is is there any way possible to mimic whatever the pcm is sending to the solenoid?
Thanks
Old Sep 4, 2018 | 09:13 PM
Mark Kovalsky
You could install on/off switches that turn the shift solenoids on and off. The pattern is two posts up from this one.
Derick6505
Aug 29, 2018 07:07 PM
dremtofford
Jun 28, 2018 02:07 PM
Husky44
May 9, 2010 11:54 AM
aocabrown
Dec 28, 2007 02:27 AM
MufassaMaxx
Jun 9, 2002 11:02 PM
