Oil drain plug torque?
Old Aug 28, 2018 | 03:46 PM
xploded's Avatar
xploded
Trailering
Wow! I'm embarrassed to say my google skills and searching here have really failed me. Can anyone tell me the engine oil drain plug torque for a 2017 super duty 6.7L diesel. Also, is there a crush washer/ plug gasket that needs to be replaced? I'm ready to do my first change and these are the last two things i need to figure out. Thanks
Old Aug 28, 2018 | 04:27 PM
N2dunz's Avatar
N2dunz
O ring.
No washer.
I don't torque.
Just snug.
O rings don't need a lot of cranking on.
Old Aug 28, 2018 | 05:05 PM
toymaster's Avatar
toymaster
http://www.hollonoil.com/OCH/Engine%...ue%20Chart.pdf
My google-fu rendered 1/4 turn past touching
In the real world I use the goldilocks method which is roughly ~ 60 inch lbs (5 ft lbs)
Old Aug 28, 2018 | 05:10 PM
h20camper's Avatar
h20camper
I just snug my oil drain plugs too but here's the spec for your 6.7 from the Ford OEM Service Manual
Old Aug 28, 2018 | 05:36 PM
rsgates's Avatar
rsgates
Fumoto valve; never looked back. I think they recently changed names Shop online EZ Oil Drain Valve | OilDrainValve.net
I installed as part of first oil change last winter. I can't seem to find the order but iirc $30 ish with the new swivel.
Old Aug 28, 2018 | 05:40 PM
harmanrk's Avatar
harmanrk
Fumoto and EZ are different companies, making very similar products. Which is better, I'm not sure there is a can of worms there to be opened.
Old Aug 28, 2018 | 10:07 PM
rsgates's Avatar
rsgates
Yeah, my bad. I just cannot find my receipt, am sure it was FUMOTO now: Fumoto® USA | Quick and Easy Engine Oil Drain Valves. It was part F-111 for my old 7.3L but for the life of me I cannot recall the thread size/part # for the 6.7L. F-316L with swivel is listed in post#5 here. I am pretty sure that's it, and is $33 now according to their site.
I got the swivel version this time around and it's even better especially with the oil pan angle. the valve also tames to oil geyser I experienced the only time I removed the plug...and set it aside for good.
Last edited by rsgates; Aug 29, 2018 at 08:34 AM. Reason: wrong attachment, supposed to be a link.
Old Aug 29, 2018 | 10:11 AM
USSenator's Avatar
USSenator
I ordered the Fumoto F106SX M14-1.5 Sx Series Drain Valve. To install it, I used a shop vac on the filler valve to keep oil in the drain pan with the oil plug removed. It worked real slick.
Old Aug 31, 2018 | 01:54 PM
xploded's Avatar
xploded
Trailering
awesome! Thanks!
Old Aug 31, 2018 | 08:23 PM
Chinookman's Avatar
Chinookman
2X!
I used the same trick on the old 7.3. Works like a champ!
Old Oct 16, 2019 | 08:46 AM
Mark Stump's Avatar
Mark Stump
[Non-answer, mostly]
I'm still rocking a 2000 F250 Diesel (7.3L)
I've never measured my torque for the drain plug.
I'm guessing I use around 15 lb*ft
which has worked well for 20 years.
BTW, I'm always surprised when loosening the drain plug--because I can probably
get it 75-80% of the way out, stop, stare at it, and still not see the first drop of oil!
Old Oct 16, 2019 | 05:33 PM
Tedster9's Avatar
Tedster9
Is that torque spec for dry or lubricated threads?
(Sorry, I'll let my self out...)
Old Oct 16, 2019 | 09:53 PM
Work Truck Fanatic's Avatar
Work Truck Fanatic
Thanks I've been looking for this info myself. Anyone knows when a Hanyes or Chilton manual will come out. I've looked online without any success finding a repair manual from a reliable source.
Old Oct 16, 2019 | 11:50 PM
Imadentguy's Avatar
Imadentguy
Laughed out loud at this :-)
MS86
May 22, 2015 02:00 PM
ttttmaxx
18
Apr 4, 2010 06:45 PM
f-1501988
2009 - 2014 F150
Mar 28, 2010 07:20 PM
jaybread
6.4L Power Stroke Diesel
Mar 23, 2009 11:04 AM
