Remote Oil Filter Location?
Old Aug 31, 2018 | 04:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by Mikulh
At the risk of asking a dumb question...
I can see how in Scndsin's case he's getting extra filtering with two filters, but what is the purpose of relocating a single oil filter?... Just easier access?
In my case with the diesel,they didn't at the time at least,make a oil filter sandwich to allow running lines for an aux oil cooler so I had to buy a remote mount oil filter,which fortunately they do make,in order to get my aux cooling lines run.
I would have preferred to just kept my filter were it was.
Old Aug 31, 2018 | 06:14 PM
BigBlue 94's Avatar
BigBlue 94
I ran a dual remote filter on the inside of the passenger frame rail, right under the core support. Mount the filter(s) so they screw in from the bottom. That way when you fill the filter(s) with new oil, it doesn't spill out as you screw them on. Each filter had an aluminum heatsink wrapped around it for a bit of extra cooling.
Old Sep 4, 2018 | 06:54 AM
TC-Countryboy's Avatar
TC-Countryboy
So you’re going to buy one of those expensive open element hot air intakes?
What is is wrong with the current location of the filter?
n
No, if I do something with the intake, I will fab something up myself where I can pull outside air. As for what's wrong with the current location I am going to assume we are back on the oil filter, and the answer is I want to simplify the cooling system, getting rid of the oil cooler mounted to the block. I have a problem with a re-accurring slow coolant leak from it.
Old Sep 4, 2018 | 05:22 PM
BigBlue 94's Avatar
BigBlue 94
Originally Posted by TC-Countryboy
n
pull the oil cooler adapter puck off and screw a FL1a on. That's the simplest route.
mine I spoke of above had the dual remote filters and the factory oil cooler still functioning. But that was 10 years ago.
Old Sep 4, 2018 | 07:05 PM
TC-Countryboy
On the 4x4 F350s with a 460/7.5l the oil filter will not fit to the block due to interference from the cross member. On older models, an adaptor is used to locate a full size FL1A filter forward of the cross member and on newer models, a heat exchanger was incorporated into the adaptor. Both setups had their own problems which I would like to avoid by relocating the filter and adding an air cooled cooler.
arayray94
Nov 21, 2017 04:25 PM
F250racer
Oct 21, 2010 11:55 AM
93_flareside
Jun 6, 2010 06:51 PM
94 XLT White/ Silver 302
1978 - 1996 Big Bronco
Jul 5, 2004 04:21 PM
cgl
Sep 4, 2001 12:35 PM
