Tail gate don't open
Old Aug 27, 2018 | 02:41 PM
petei's Avatar
petei
What can be wrong?
Old Aug 27, 2018 | 03:05 PM
Kdawg89's Avatar
Kdawg89
If the truck is locked the tailgate will also be locked. Do the doors open?
Old Aug 27, 2018 | 03:22 PM
petei's Avatar
petei
None of the button work tail gate,fob,inside cab.I see that the tail light turn on and off when I push the button.
Old Aug 27, 2018 | 03:29 PM
ford390gashog's Avatar
ford390gashog
If it's a higher trim truck with release, push the tailgate in at the same time while releasing. Then check your rubber bump stops and make sure they are facing the correct way. They will bind the tailgate and cause a no release.
Old Aug 27, 2018 | 05:52 PM
spadoc's Avatar
spadoc
I just had my actuator replaced last weekend
Old Aug 27, 2018 | 08:09 PM
zeroo's Avatar
zeroo
At the very least you should get the lock release when a button is pushed.
rtraviator
Nov 23, 2018 06:07 PM
Warpburn
Aug 23, 2018 08:29 AM
makthenif
Nov 29, 2010 06:12 PM
That_Guy
19
Jan 4, 2009 05:32 PM
LiverSpots
Oct 20, 2003 11:25 AM
