'76 cab mount question before purchase
Old Aug 27, 2018 | 02:02 PM
bcapps's Avatar
bcapps
Went to look at a '76 F150 over the weekend, overall super clean one-owner truck, with the exception of the cab mounts up front, pics below. I poked around a bit, and the metal seems solid everywhere else. I've read elsewhere that bad cab mounts can put weight on the steering column, and the steering on this truck had a good bit of play in it. Basically just looking for input from the community as to whether or not y'all think this could be a major issue later on or if I'd be safe pulling the trigger on this one and dealing with it down the road when I plan on doing body work and paint. Any input would be appreciated.
Thanks
Old Aug 27, 2018 | 02:38 PM
flatbedfordguy's Avatar
flatbedfordguy
Those are pretty crusty and will eventually collapse in on themselves. Just something to keep in mind if/when you buy, maybe use it as a bargaining chip to drop the asking price.
Old Aug 27, 2018 | 03:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
They are going to need some attention sooner than later. Dvrs side looks worse, the issue with the settling cab is really noticeable if you have a standard trans. A settling cab causes binding in the steering, not looseness. A "good bit of play" in the trucks steering is your standard worn out steering shaft rag joint, worn out steering shaft and or steering box itself.
Are you planning on pulling the cab come paint and body work time? That sure makes it easier to replace a cab mount.
What is clamped to the inside of the passenger side radius arm?
Old Aug 27, 2018 | 03:59 PM
beartracks's Avatar
beartracks
Your kidding right? The cab is totally rusted out.
Old Aug 27, 2018 | 04:16 PM
User 71024's Avatar
User 71024
You live in New Mexico, you're not allowed to comment on Rust.
Old Aug 27, 2018 | 04:23 PM
flatbedfordguy
Lol! Back east those cab mounts would actually be considered pretty good.
Old Aug 27, 2018 | 04:54 PM
beartracks's Avatar
beartracks
Holy hole in a donut Bat Man! The Batmobile has a Bat crack.
Seriously my friend, if you are serious that's dangerous.
Old Aug 27, 2018 | 10:25 PM
77&79F250's Avatar
77&79F250
X2 on it is not that bad IMO, yes each cab corner has some rust and maybe a small bit on the piece behind it on the passenger side. I have seen WAY worse still on the road.
Old Aug 28, 2018 | 06:59 AM
bcapps's Avatar
bcapps
Thanks for y'all's input. I was planning on just jacking the cab up a bit, slipping new mounts on, and tacking them in place, but by everyone's reaction, seems like it might not be advisable to drive it 500 miles of backroads home before having that done. I'll keep looking.
Old Aug 28, 2018 | 08:35 AM
Circa 78''s Avatar
Circa 78'
Personally i removed my cab, laid i on its back and did my repairs then undercoated it thouraly, by the way...you can repair the frame cab mounts as well, i would bet your project to be truck most likely is a candidate, difficult to see until you remove cab to frame bushings.
Good luck in your hunt.
Old Aug 28, 2018 | 08:50 AM
Circa 78''s Avatar
Circa 78'
Getting ready to undercoat it
Undercoated completely.
C@b to frame mounts repaired n ready to reinstall
Old Aug 28, 2018 | 01:14 PM
77&79F250's Avatar
77&79F250
I'd drive it for 500+ miles like that, its not that bad IMO.
Old Aug 29, 2018 | 11:21 AM
FuzzFace2's Avatar
FuzzFace2
Are the floor pans sitting on the top of the frame rails?
If not and even then I would drive it 500 miles home so I could dig into it.
BTW I spent 54 years in New England so I do know what rust is!
Dave - - - -
Old Aug 29, 2018 | 12:01 PM
flatbedfordguy
Those mounts do need attention but they're not falling apart anytime soon....hell, they could last another 10yrs like that, these are tough old trucks.
If you really want the truck I wouldn't scrap the deal over this cab mount issue, it will surely make the 500 mile drive home, it may break down for some other reason but I can assure you it will not be because of the cab mounts.
OLDBLEU66
Apr 3, 2016 07:35 PM
Salty Dog
Sep 21, 2014 12:38 AM
judi48
15
Mar 25, 2010 09:54 PM
vanwho
Virginia Chapter
May 29, 2007 06:26 PM
FLgargoyle
29
Apr 28, 2005 10:09 PM
