14 F350 upper shock mount broke bolt
My passengers side upper shock mounting bolt snapped in half today while l was trying to take the nut off. Is there an easy way to replace that bolt? I see the upper shock mount bolt is pressed into a bracket that is riveted to the frame.
Thank you in advance.
Terry
Terry
Thank you Rudiak.
This is the route I am going. The whole Ford setup seemed flimsy..
I,
1) Used a grinder and "X" the rivets that hold the upper shock mount, there is 4 of them.
2) Airchissel the heads off.
3) Airhammer the rivets out from the outside.
4) I figure the only reasonable way to prevent this in the future is pictured below.
At $200 this is not cheap but neither are my Icons and I don't want to mess with a broken bolt again.
I,
PancakeF150
08-24-2018 02:44 PM
