Shock mount bolt
Old Nov 8, 2009 | 10:19 AM
blloyd's Avatar
blloyd
Shock mount bolt
Since it is Sunday and the dealership is not open, thought I would throw this question out there.
I Installed a new set of Monroe Sensa Trac shocks on the 92 XPL last night and the lower shock mount bolt broke off.
Went to the local NAPA and OReillys and they do not even show this bolt as a part they carry.
Is this a dealer part only ??
Old Nov 8, 2009 | 11:31 AM
aquanaut20's Avatar
aquanaut20
This bolt is part of the spring mount, it is available from the dealer $$$, but there is an aftermarket kit to replace the bolt. The old shock bolt has to be ground/drilled off the mount the replacement kit pin has threads on both ends.
In an emergency, drill through the mount, use a longer Gr8 bolt, thread or weld to the mount.
Old Nov 9, 2009 | 07:06 PM
blloyd's Avatar
blloyd
I was told by the local Ford dealership that the bolt is actually part of the Radius Arm and I will have to replace it to fix the problem !
Someone tell me he is wrong, cause this arm is over $70.00
Old Nov 9, 2009 | 07:12 PM
aquanaut20's Avatar
aquanaut20
Yes it is that is why a gave you the alternate fix, your call...
Picture worth 1000 words.. http://www.explorerforum.com/forums/...d.php?t=219180
Old Nov 9, 2009 | 07:38 PM
blloyd's Avatar
blloyd
Thanks aquant, especially for the link to the photos !
I have a better understanding of what needs to be done now !
Seems like a screwy design with the shock bolt on the Radius arm !
Old Nov 9, 2009 | 07:49 PM
aquanaut20's Avatar
aquanaut20
If you check one of the pics, there is a part number for you..
Old Nov 11, 2009 | 05:16 PM
blloyd's Avatar
blloyd
Just wanted to let you know, I took the XPL to a Wheel Alignment place here near my house and they used the universal bolt I got at NAPA and everything is fixed now.
Cost $70.00 labor Bolt was $10.00
In a way it is a good thing I took it down there, cause I found out my buddy forgot to tighten down the rear shocks after he installed them.
Was wondering why I had such a rattle !
Thanks for your help Aquanaut20 !!
ohbrian
31
Sep 19, 2019 12:29 PM
jfletcher72
6.7L Power Stroke Diesel
Oct 13, 2015 08:28 PM
kabur66
Sep 19, 2013 06:29 AM
dpoc
Nov 18, 2012 06:20 PM
mgriffin
Mar 15, 2002 08:35 PM
