What's the advantage of a remote location with so much room under the hood?
It gives you options. It also removes a lot of heat, that would be in the engine compartment, else where.
With the remote mount set up you want to do your best to keep as much of the heat in the exhaust system as possible. So that means ceramic coating the system or header wrapping it.
It also requires a scavaging pump to return the oil to the engine.
And a side benefit of the remote mount turbos is. The longer tubing run from the compressor housing to the engine or intercooler acts a little like a intercooler. So you can get a little temp drop from it.
Sick6 knows what he's doing. He's the one to talk to about the remote mount turbo set up.
