79 F-100 Turbo 300-6 Sleeper
Old 08-18-2015, 05:01 PM
Sick6's Avatar
Sick6
Sick6 is offline
Go before show, going to the track Friday, will post results.
Stock 88 efi bottom end with hv oil pump 1xx,xxx miles
Stock valved head, mild porting, pinned stock 3/8 studs, Isky 7005-12 dual springs
Offy C intake, HD exhaust mani. 2.5" all the way back to turbo
comp pushrods(not sure if better than stock) stock rockers(adjustable)
Crower 284 hydraulic cam 106* intake lobe center. Shifting @5100-5200
Holley 600dp modded for e85, running 91+torco now
New stock motor mounts and nylon torque strap
C6 transbrake, "e" lever, billet servo, 3100 flash stall, stock clutches and band
1350 u-joints, custom shaft
Lakewood 90/10 shocks up front
Lakewood traction bars in back
MT e.t street radials in back 275/60/15
9" 2.75 gears, 31 spline, stock wore out locker
T72 ebay turbo t3 flange .84 a/r will hit 20 psi on the brake
16 gallon fuel cell(in a red box) 450 lph walboro in cell(for future)
60m/40w methanol injection m10 nozzle (130*f intake temps)spray pre-turbo
Rear mounted battery
3920# race weight(on the line with me in it full tank of fuel)
Future upgrades:Correct roller rockers, full spool and nitrous(small shot)
Hooks on the street leaving at 12 psi.
Dale
Old 08-18-2015, 05:13 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
That's a interesting setup it reminds me of the STS turbo kits. I'm not sure if they are even around anymore but they seemed to pioneer that idea for the F body cars a while back.
Old 08-18-2015, 05:26 PM
Sick6's Avatar
Sick6
Sick6 is offline
It works very well with the 3100 stall. I was worried with all the horror stories of rearmounts, but with this combo, exhaust backpressure is at 37 psi with 20 psi of boost, for a 1.85:1 ratio. 2:1 ratio is considered good for a street/strip machine even if front mounted. Every ounce behind the rear axle on a street/strip truck is good!
Dale
Old 08-18-2015, 05:40 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,601 Likes on 1,305 Posts
Reps given for what I believe to be the first working 300 turbo thread ever on FTE. AFAIK. IIRC. YMMV.
Old 08-18-2015, 05:54 PM
Sick6's Avatar
Sick6
Sick6 is offline
Thanks 85 It's been fun but a lot of work getting the combo good. I was nearly at the end of my streetable rope with the comp 268h cam only good to 4500 rpm at 20 psi. It hauled, but not quite enough. Then I took the owner of a new 375 hp Challenger for a ride. He was not interested in racing after the ride.
I had the Crower cam sitting there deamed as not being turbo friendly, resulted in pulling like a freight train to 5000 rpm and a good 50 asspower more. Now it's a bit scary on the street so i'm happy.
Dale
Old 08-18-2015, 06:25 PM
co425's Avatar
co425
co425 is offline
That's very cool. Love to see a drag strip video!
Old 08-18-2015, 07:09 PM
Sick6's Avatar
Sick6
Sick6 is offline
Usually she has the video on FB before I even get my timeslips! We will bring a white turbo 3.8 T-bird along also, ran 12.43 last year before head and intake swap. We will prolly race each other, his is lighter and faster now with the swap. I am only running the 1/8 mile at this time. If I can't post the video here I will put up a link.
Dale
Old 08-18-2015, 08:47 PM
tonymontanna1983's Avatar
tonymontanna1983
tonymontanna1983 is offline
Can't wait to see this
Old 08-18-2015, 10:19 PM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
Interesting setup! Great looking truck too
Old 08-18-2015, 11:09 PM
burnthelight88's Avatar
burnthelight88
burnthelight88 is offline
If some new guy came on the forums and said he wanted to build a turbo 300, I'd have laughed myself right off the couch. You sir, have quite the imagination. Looks sweet, but I HAVE to see the video.
Old 08-19-2015, 10:01 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
What kinda pistons are you running? The Meth injection helps cool stuff to prevent detonation?
Nice truck, btw!
Old 08-19-2015, 10:34 AM
Sick6's Avatar
Sick6
Sick6 is offline
Stock 88 efi as listed above. Meth cools the charge and adds octane to allow more timing and boost, water helps control combustion and cool the pistons. Meth adds richness to the mixture, i'm adding a higher percent of meth as I go to get a 80m/20w mix which should be optimum. Then I will rejet the carb if needed depending on afr. I'm a little leaner than I like right now, so hoping 80/20 will richen a bit and all will be good. Then I may turn the boost up to 24 psi at the track if i'm safe. I'm am going to get a good pass in at 20 psi before I touch anything just in case.
Dale
Old 08-19-2015, 12:12 PM
Boss08v10's Avatar
Boss08v10
Boss08v10 is offline
This is an awesome truck, would love to see a bunch more pictures of the turbo pumbing from under the truck.
Old 08-19-2015, 12:27 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
where u get that intake, i got a 300 and no stock carb but havea 4 barrel carb here
Old 08-19-2015, 01:21 PM
'75HB250's Avatar
'75HB250
'75HB250 is offline
Super neat build! The look is perfect for a street sleeper.
20 psi on the stock pistons??? Is that considered "pushing it"? I'm not that familiar with these engines, but that seems like alot on any stock piston.
I bet it sounds cool too.
Quick Reply: 79 F-100 Turbo 300-6 Sleeper
