I received my flood module from flea bay today and installed it. It was out of a salvaged vehicle. I have the vin if that matters. It was on the tag. Anyway the floods still don't work. No worries I have my adapter on the way so I can make the changes with Forscan. I would think that a truck that came with a flood adapter would be programmed already. Now I may be missing something. I have the tow mirrors, I installed the whole door wiring harness on both doors. I swapped out the A/C bezel with the one ready for the switch that I installed that was already factory wired. And today added the flood module. I don't think I need anything else unless there is a fuse I haven't added yet.
Edit 1: I checked and the flood light module fuse is in spot 16 in the battery junction Box
Edit 2: If I do what is called the spotlight module wiring modification do you think the spotlights will work without using forescan to turn them on?
Yep Finished it up this morning. I wanted to make it a permanent fix. I didn't want the jumper wire to fall just enough to spark and fry my PCM. Now all I need to do is get the puddle lighta working and I'll be set
