flood module
Old Aug 18, 2018 | 08:37 PM
PAWZ Guitar Company's Avatar
PAWZ Guitar Company
flood module
I received my flood module from flea bay today and installed it. It was out of a salvaged vehicle. I have the vin if that matters. It was on the tag. Anyway the floods still don't work. No worries I have my adapter on the way so I can make the changes with Forscan. I would think that a truck that came with a flood adapter would be programmed already. Now I may be missing something. I have the tow mirrors, I installed the whole door wiring harness on both doors. I swapped out the A/C bezel with the one ready for the switch that I installed that was already factory wired. And today added the flood module. I don't think I need anything else unless there is a fuse I haven't added yet.
Edit 1: I checked and the flood light module fuse is in spot 16 in the battery junction Box
Edit 2: If I do what is called the spotlight module wiring modification do you think the spotlights will work without using forescan to turn them on?
Old Aug 18, 2018 | 10:51 PM
PAWZ Guitar Company
The floods came on when I jumpered pins 1 and 2 on C2506B. I need to make it more permanent tomorrow Morning.
Old Aug 18, 2018 | 11:21 PM
ford390gashog's Avatar
ford390gashog
Keep pins 1 and 2 jumped permanently. It allows you spotlight at any speed and is a common mod.
Old Aug 19, 2018 | 01:44 PM
PAWZ Guitar Company
Yep Finished it up this morning. I wanted to make it a permanent fix. I didn't want the jumper wire to fall just enough to spark and fry my PCM. Now all I need to do is get the puddle lighta working and I'll be set
ojh
Nov 26, 2017 11:38 PM
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
jm ray
Oct 2, 2007 03:37 PM
bronco_rick
Electrical Systems/Wiring
Apr 17, 2007 03:57 PM
beeshoo
Apr 15, 2007 01:52 PM
